Material slots undo is inconsistent in non-Object modes
Confirmed, NormalPublicKNOWN ISSUE
Broken: 3.0
Material slots undo is inconsistent. Sometimes multiple slots are added/removed in one undo, and sometimes undo won't change back mode.
tab to edit mode
add a material slot
undo twice
add another material slot
undo
both material slots will be undone. Also undo won't go back into edit mode.
if you redo both material slots are redone at the same time.
@Gilberto Rodrigues (gilberto_rodrigues) , thanks for the report. Similar report I noticed a few moments ago T88674: Undo 3 steps at once in edit mode..
I guess single report would be fine for undo inconsistency in material tab. I can reproduce this as well.
(I found some extra patterns where it was inconsistent)
If I put in one report it would be confusing
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.EditedJun 3 2021, 11:41 AM
Ok, Confirming. But I assume one task would be enough for undo inconsistency in material tab :)
(Correct me if correct tag is core here)
Bastien Montagne (mont29) renamed this task from Material slots undo is inconsistent to Material slots undo is inconsistent in non-Object modes.Jun 24 2021, 12:31 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".
Bastien Montagne (mont29) added a project: Restricted Project.Jun 24 2021, 12:37 PM
Bastien Montagne (mont29) moved this task from Backlog to Known Issues on the Core board.
Bastien Montagne (mont29) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Jan 27 2022, 5:56 PM
