This is task is for a node that calculates the lengths of splines.
- The main complexity is that each spline has its own length, and the curve may have multiple splines.
- Therefore there are two output modes.
- The first (and default) outputs the total length of all of the splines as a float.
- The second creates a float attribute on the spline domain and fills it with the values for each spline.
Further Questions
- The name "Calculate Curve Length" might be better (more clear), but it is longer.
Implementation
Implementation is trivial, this can use the Spline::length() function.
