Basis shape key not behaving as expected
Closed, DuplicatePublic
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Strange behavior related to basis of shape keys. When exporting this mesh it exports it as though "out" is the basis shape key. When you hit "+" to add a shape key it is by default the "out" shape key even though "out" is not the basis.
just press "+" to add a shape key or export as gltf2 (probably other templates as well)
Can confirm in this particular file.
Similar to T67185: Shape Keys Behaving Like a Duplicate of Previous Key , I assume there have been modeling modifications on the mesh after adding the shapekey(s) that changed vertex count / topology?
This only has limited support and can lead to some issues, see the above report as well as https://blender.stackexchange.com/questions/19296/can-i-fix-broken-shape-keys-after-editing-basis.
That being said, you can fix this in you case by:
  • open your file
  • select OuterCorners object
  • enter editmode
  • select all vertices
  • select the Basis shapekey
  • from the menus, execute Vertex > Blend from Shape
If I do this, I can create a new shapekey that doesnt seem like a duplicate of the other shapekey...
Will merge this into T67185 [which has been closed for now because it is working as intended (even though this could be really improved upon...)]
