Grease Pencil. Draw tool pressure - curve widget button missing?
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-16 05:49, hash: rB0e581f619670
The Blender manual for the Grease Pencil draw tool says:
Use Pressure (pressure sensitivity icon)
Uses stylus pressure to control how strong the effect is. The gradient of the pressure can be customized using the curve widget.
But I see no button (or any other way) to access a curve widget for mapping the draw tool's pressure. Should there be one?
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jun 3 2021, 1:58 PM
For some reason these were re-organized to only show in the Properties Editor in rBb571516237a9: GPencil: Include new Brush random curves
@Antonio Vazquez (antoniov): wouldnt it make much more sense to have these in the sidebar as well? What was the reasoning to exclude the curves from there?
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Information from Developers.Jun 3 2021, 1:58 PM
This would also show the curve widget in the sidebar:
1
2
3diff --git a/release/scripts/startup/bl_ui/properties_paint_common.py b/release/scripts/startup/bl_ui/properties_paint_common.py
4index f3462dfb35d..f96df8843d9 100644
5--- a/release/scripts/startup/bl_ui/properties_paint_common.py
6+++ b/release/scripts/startup/bl_ui/properties_paint_common.py
7@@ -1235,7 +1235,7 @@ def brush_basic_gpencil_paint_settings(layout, context, brush, *, compact=False)
8 row.prop(brush, "size", text="Radius")
9 row.prop(gp_settings, "use_pressure", text="", icon='STYLUS_PRESSURE')
10
11- if gp_settings.use_pressure and context.area.type == 'PROPERTIES':
12+ if gp_settings.use_pressure:
13 col = layout.column()
14 col.template_curve_mapping(gp_settings, "curve_sensitivity", brush=True,
15 use_negative_slope=True)
16@@ -1244,7 +1244,7 @@ def brush_basic_gpencil_paint_settings(layout, context, brush, *, compact=False)
17 row.prop(gp_settings, "pen_strength", slider=True)
18 row.prop(gp_settings, "use_strength_pressure", text="", icon='STYLUS_PRESSURE')
19
20- if gp_settings.use_strength_pressure and context.area.type == 'PROPERTIES':
21+ if gp_settings.use_strength_pressure:
22 col = layout.column()
23 col.template_curve_mapping(gp_settings, "curve_strength", brush=True,
24 use_negative_slope=True)
Grease pencil brushes have a lot of curve widgets, not just Radius and Strength (see random settings for example), the decision was to keep as clean as possible the topbar only with the toggle buttons to activate the use of the tablet preassure and put all the curve widget in properties. Those settings are for advanced user and is not something that need tweaking very often.
Tomasz Kaye (bitbutter) closed this task as Resolved.Jun 3 2021, 3:01 PM
Tomasz Kaye (bitbutter) claimed this task.
Thanks for the clarification! i'll close the ticket if everyone's ok with that
Was not talking about the top bar, I was refering to the discrepancy between the Properties Editor and the sidebar (they are available in the Properties Editor but not the sidebar -- which I find confusing):
I see, in that case it seems to be an omission when all the widgets were moved to properties. @Antonio Vazquez (antoniov) could you take a look?
@Philipp Oeser (lichtwerk) This looks that we missed to add these properties to the panel or that we decided to avoid too many things, don't remember now, but .if @Matias Mendiola (mendio) agrees in the UI side, your patch is ok.
Sure, properties and side panel should work the same
@Philipp Oeser (lichtwerk) do you commit the change or I can do it if you can't?
