Geometry Nodes: crash when using negative values in the "line mesh primitive" node
Closed, DuplicatePublic
Graphics card: NVIDIA Quadro P5200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-07 22:19, hash: rBef5a362a5b24
Using negative values into the Count Input socket of the Line Mesh Primitive node crashes Blender (like in the image attached)
  1. Default factory reset file
  2. Add a Geometry Node modifier to the default cube, create and conect a Line Mesh Primitive node to the Output node.
  3. Conect a Value Node to the Count Input and change it to a negative value.
In the image below the Value node is 4. When the Value is negative Blender crashes. I checked this with other Mesh Primitive Nodes but didn't get more crashes (it seems it only crash with the Line Primitive Count Input socket)
Related Objects
