Zoom not working the same back and front.
When zooming from the back, it will not move past the 3d module.
When zooming from the front, it will work ok and go beyond the 3d module.
Have tried it with mouse and wacom.
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.Jun 16 2021, 9:17 PM
Is there a blender version where the behavior is different ?
Will check if I have another version installed except 2.93
Problem also in 2.81.16
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Jul 5 2021, 7:24 AM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Jul 7 2021, 3:47 PM
I'm not sure I understand the bug.
Zoom has a limited distance.
If you approach (zoom in), this distance decreases.
If you move away (zoom out), this distance increases.
If you rotate (orbit) the view, the zoom distance does not change.
If you want this zoom distance to be the distance of the selected geometry, you might prefer to enable the "Orbit Around Selection" option. This option affects zoom as well.
If you prefer this distance to be up to the geometry pointed by the mouse, you might prefer to enable "Auto Depth".
Is this information useful?
For help using Blender, you can try one of the community websites: https://www.blender.org/community/
Remember that this bug tracker is only for bugs and errors.
erick mav (ymca) added a comment.EditedJul 7 2021, 11:59 PM
"Orbit Around Selection" didn't help.
Enabled "Depth" helped more.
Tried it on both sides.
The problem is knowing if it's a bug or a feature.
Doesn't seem like a bug to me.
The behavior could be improved, but this is not the scope of the bug tracker .
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
