Screen freeze during "draging" actions.
Operating system: Linux-5.8.0-55-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: Mesa Intel(R) HD Graphics 530 (SKL GT2) Intel 4.6 (Core Profile) Mesa 20.2.6
Screen freeze during dragging actions. Freez mostly appear when scrub at action window or resize brush while sculpting etc.
Screen freez during draging actions. Freez mostly apear when scrub at action window or resize brush while sculpting etc.
To unfreeze i have to log out (ctrl alt delete), but it shout down all programs. All function seems to be working "under" the freezing screen(except blender). And cursor stay at same position, but have noisy smal moves.
It heppen suddenly, but try actions with pressed mouse keys and dragging.
Can not reproduce on 3.0.0 (rB4891da8ae225).
System Information:
Operating system : Windows-10-10.0.18362-SP0 64 Bits
Graphics card : AMD Radeon(TM) 535 ATI Technologies .
Please mention broken blender version.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jun 16 2021, 3:18 PM
@Hubert Piątkowski (Bobo) , thanks for the information. So many add-ons are enabled which I can see in system-info.txt.
Please try again with factory settings (File -> Defaults -> Load Factory Settings) ?
I can't test it in default. I work full time and it can slow my workflow. I disable half of addons( left mostly import-export) and problem did not desapear.
Blender freezes when scrolling using middle mouse button. Releasing MMB while moving is more likely to crash it. It happens with 2.83 LT and 2.93 LT. Mostly using 2.93.
Have to use task manager to force quit blender.
Windows 10 on MS Surface Pro 7, quad core i7. 16GB ram.
Some 3rd party add-ons are also enabled but could not blame them without much information.
So far I am not able to reproduce the issue.
Please check if your graphics driver is also up-to-date otherwise to update them, refer: https://docs.blender.org/manual/en/latest/troubleshooting/gpu/index.html#windows
Graphic drivers was the first thing I checked, for both cards. I believe that Blender crash only or mostly when runs on integrated Intel HD Graphics 530.
Most of this third party add ons only runs python commands that are assigned to interface buttons.
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Jun 30 2021, 11:25 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Aug 10 2021, 4:41 PM
I think we really need to test this once with complete Factory Defaults.
(no need to worry about loosing defaults, all will be back to usual if you restart blender).
So please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Philipp Oeser (lichtwerk) closed this task as Archived.Aug 18 2021, 3:48 PM
It is not closed. It still happens with clean install no Add-ons
Pratik Borhade (PratikPB2123) reopened this task as Needs Triage.Aug 20 2021, 1:56 PM
Thanks for checking. Report was closed because no reply was received within a week (As said in the Triaging Playbook)
Could you please add the log files?: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html#crash-log
Does this only happen with the file which you have provided or is this something you can reproduce with every file?
Also, can you recreate the issue with any other blender version? (eg. 3.0.0, 2.92, 2.83)
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Aug 20 2021, 2:05 PM
see also:
https://developer.blender.org/T88420
These log files are launching with blender_debug_log.cmd. Just the default cube colored red.
It froze and had to force quit{F10297045}
Now running with blender_debug_gpu.cmd
Default cube. When setting to cycles GPU Not how cube becomes gray rendered viewport display. trying to go back to any other preview mode just makes it non responsive and have to force quit.
May be this is expected. see: https://docs.blender.org/manual/en/latest/render/cycles/gpu_rendering.html#why-is-blender-unresponsive-during-rendering
While a graphics card is rendering, it cannot redraw the user interface, which makes Blender unresponsive
I think this appears for the first time only. Did you wait till the end of compilation of the kernel?
Hi, can you please confirm this?
Also note that Blender 3.0 removes OpenCL rendering support with Cycles-X merge as said in https://code.blender.org/2021/04/cycles-x/
Philipp Oeser (lichtwerk) closed this task as Archived.Oct 27 2021, 9:41 AM
