Operating system: Windows 10 Home 64 bit
Graphics card: GeForce GTX 1650 SUPER (apparently a 3070 user also experienced this problem)
Broken: 2.91, 2.93, 3.0.0, 3.0.0 (Cycles-X) ...and probably more, if not all, versions which allow OptiX rendering.
Worked: (!)
Cycles rendering set to OptiX yields darker, noisier diffuse lighting outside a square area under a light in this example file.
This only becomes visible when the plane is large, facing upward, and located in the [-1, -2] range along the Z axis.
From factory settings:
- Add a plane.
- Move it to (0, 0, -1).
- Scale it up by a factor of 100.
- Render using OptiX acceleration.
Thanks for making amazing free software, devs!👍
