Make Planar Faces operator causes assertion failure with non-planar faces
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-21 16:25, hash: rBb11a463e4fcd
Worked: Assert was introduced by rB819152527fd4, so any prior commit should be fine
Running the Make Planar Faces operator on a mesh with one non-planar face and one planar face causes an assertion failure.
  1. Open the attached file
  2. Select either object and go into edit mode (Cube.001 was auto-generated and Plane was hand-made)
  3. Select all faces
  4. Run the Make Planar Faces operator
  5. Assertion failure
This is the same assert that T89345 hits, but with a different operator.
Of course, this only happens on debug builds.
Relevant assert:
#ifdef DEBUG
  /* The face normal is used for projecting faces into 2D space for tessellation.
   * Invalid normals may result in invalid tessellation.
   * Either `face_normal` should be true or normals should be updated first. */
  BLI_assert(face_normal || BM_face_is_normal_valid(efa));
#endif
Stack trace: P2195
Fen (chemicalcrux) updated the task description. (Show Details)
Jesse Yurkovich (deadpin) changed the task status from Needs Triage to Needs Information from User.Jun 22 2021, 6:27 AM
Can you attach that .blend file? I attempt to reproduce using my own mesh creation but did not succeed.
Fen (chemicalcrux) added a comment.EditedJun 22 2021, 2:02 PM
Oooooooops, I forgot to actually attach it...
Well, the task is resolved now, but, for posterity:
