Can't export nor Apply geometry nodes (OS system freezes).
Operating system: Kubuntu
Graphics card: AMD Vega 8
Broken: Bug happens on 2.92.1 (last release) and 2.92.2 (daily build)
Worked: None.
Tried to apply a basic geometry nodes modifier, it makes my OS to freeze and need to reboot.
Tried to export into an OBJ and the other modifier stack is applied, but not the geometry node is exported into the OBJ.
Tried to apply the geometry node modifier.
Export as OBJ.
Can't reproduce on Windows 2.92
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jun 28 2021, 12:18 PM
Cannot reproduce, please try again in a fresh build from https://builder.blender.org/download/daily/
The fact that geometry resulting from Point Instance nodes after applying/converting to mesh is the same T89472: Object using Point Instance GN node can not be converted to mesh.
So, could be a duplicate of T89472, but waiting for feedback regarding the freeze in a fresh build
Can confirm my PC lags/enters some freeze cycle with daily build of 3.0 and 2.93.2
Can't confirm nothing, but It's the same freeze I get sometimes randomly when I hit Save, which sometimes creates an empty file (I have to use the .blend1 backups to restore my project).
On windows I get blue screen of death randomly, when I use some intensive 3D app.
Can't confirm but I'm guessing is a hardware issue since I'm using an integrated AMD card (Vega 8).
EDIT: Can confirm the point instance gets converted to mesh after Ctrl + A (Make instances real) but not when I hit apply in the modifiers stack nor gets exported when I export to OBJ.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Jul 10 2021, 8:05 AM
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Feb 25 2022, 4:48 PM
Since this is an OS freeze, can you check the system logs and see if there is anything interesting?
Can you go to a different TTY when the freeze happens and check the output of dmesg? Ctrl + Alt + F2, login, then execute sudo dmesg.
If you can't go to a different TTY, you can try sudo journalctl -b -1 after you reboot.
Typically, there will be some errors are the very end.
Robert Guetzkow (rjg) closed this task as Archived.May 10 2022, 11:13 AM
