Operating system: Linux (Debian 11)
Graphics card: NVIDIA RTX 2060
Broken: 3.0.0 Alpha (e1a719c0433b)
Worked: it doesn't work on Blender 2.93.1 stable too.
When a collection is set to Indirect Only, and thus should not be directly visible, geometry generated by Geometry Nodes inside said collection ignores the setting and appears as visible.
the incorrect behavior, with Geometry Nodes enabled.
the correct behavior, when the view layer visibility of Geometry Nodes is disabled
- Apply a geometry node modifier to an object.
- Place said object in a collection.
- From the Outliner, set the aforementioned collection as "Indirect Only".
- Observe the incorrect behavior.
A simple .blend file is attached, which clearly shows what is happening.
I've tested this on both Blender 3.0.0 and Blender 2.93.1. In both cases, the error appears.
