Strange "Volume on Plane" Behavior (bug?)
Graphics card: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47
Broken: version: 3.0.0 Alpha, branch: cycles-x, commit date: 2021-07-05 15:23, hash: rB048a515ef428
Appears in both regular Cycles in 2.93 and Cycles X in 3.0.
Like in the Blend file attached, when looking at objects through a plane with a volume shader, these objects somehow get affected by the volume, but the space in between them (so the world, where there are no objects) isn't filled with fog.
I'm wondering if the fact that fog even appears in the first place is an actual bug or not, as this behavior is kind of similar to having glass on that plane instead of volume, but even then the world/background is also affected by the glass.
I couldn't find anything related to that in the documentation nor in any discussion/forum/thread/video.
Of course, volume shaders aren't supposed to be used on non-manifold objects, but I still wanted to bring this up, at least to see if it's a bug, or a design problem or an intended/expected behavior (I assumed that volumes would just be disabled when used on non-manifold meshes)
Just open the blend file and preview the scene with Cycles, it's all there.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jul 8 2021, 5:52 AM
Can you upload screenshot?
This is behavior I see, and it is same in older versions, not sure if this is bug though.
It is the behavior I'm talking about yes, I was also wondering if it was a bug or not.
If it's a normal behavior, then the task can be removed
Richard Antalik (ISS) closed this task as Archived.Jul 12 2021, 2:30 PM
This really seems to be normal behavior, so closing. Thanks for reporting anyway.
