Cloth disk cache is not read on library overrides when original linked data is already set to use 'Disk Cache'
Graphics card: NVIDIA GeForce GTX 1080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-09 23:23, hash: rB62d9dabc7db4
Baking cloth with file disk cache used to work. Now it will get ignored on reload
Unpack the following zip
Open Library Override.blend
Make sure Disk Cache is enabled and Use Library Path is disabled
Click Bake
Save
Reload
The cloth simulation is gone
Here's a video of the problem
Daniel Salazar (zanqdo) renamed this task from Cloth disk cache is not read on library overrides to Cloth disk cache is not read on library overrides (regression).Jul 10 2021, 8:39 AM
Can not reproduce with provided steps on 3.0.0 (rB62d9dabc7db4).
Operating system : Windows-10-10.0.18362-SP0 64 Bits
Graphics card : AMD Radeon(TM) 535 ATI Technologies .
@Daniel Salazar (zanqdo) , can you please mention the working version also?
Hey man, do you mean it works for you? This is related to the Milestone 1 of this project
We made sure the basics for disk cache worked back in 2.92. I'm trying to find out what happened.
@Daniel Salazar (zanqdo) , unsure what behavior is expected but seems same output for version 2.92 and above. (sorry for polluting the task)
At least I can say the animation is not lost after reloading the scene.
I'm not sure what's going on on your side but I've added a video to the report
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jul 13 2021, 11:35 AM
I can confirm.
From a first quick look it also seems like the override setting on Disk Cache and Use Library Patch is not consistent?
If I enable Disk Cache and disable Use Library Patch, then save the file and revert/reopen, the setting is back to the original (this should not be the case, right?)
Bastien Montagne (mont29) moved this task from Backlog to Bugs on the Core board.
Please do not add bug as children of TODO/design tasks...
This not a regression actually, that specific scenario never worked.
Issue with this case is that disk cache is already enabled in lib data (unlike what would happen by default). So there is nothing to override, and therefore no override rule is created for this setting.
But...... ClothModifier copy code just create a new empty PointCache, which by default has this setting disabled. Since there is no override rule, it remains like that in the override.
Fix incoming (note that issue could be present in other point cache usecases, but am tired of this code, it's is horribly badly handled, in a completely inconsistent way all over the codebase... It's just old system that needs complete redesign. so doing bare minimal changes needed to get this working for now).
Bastien Montagne (mont29) renamed this task from Cloth disk cache is not read on library overrides (regression) to Cloth disk cache is not read on library overrides.Jul 14 2021, 12:31 PM
Bastien Montagne (mont29) renamed this task from Cloth disk cache is not read on library overrides to Cloth disk cache is not read on library overrides when original linked data is already set to use 'Disk Cache'.
Hey man I'm sorry but there's no way I can make this thing work :( rB4be166b6b582
Daniel Salazar (zanqdo) reopened this task as Confirmed.Jul 15 2021, 5:58 AM
