data copy is ommitting vgroups
Operating system: Windows 10
Graphics card: 3090 / 3060 / 1050ti
Broken: (Current Builds) (3.0.0 hash: fafd21b14c23, master, 2021-07-22)
Worked: (2.93.1 hash: d6b1d35bf874, master, 2021-07-12)
Caused by rB3b6ee8cee708: Refactor: Move vertex group names to object data
Data copy is deleting vgroup data in 3.0 builds since the 12th.
Running this script deletes the vertex group which began happening in 3.0 builds after the 12th.
import bpy
# all vertices belong to a single group
context = bpy.context
obj = context.object
#get evaluated object
obj_eval = obj.evaluated_get(context.evaluated_depsgraph_get())
print(obj_eval.vertex_groups[:]) #the evaluated object has groups
# and create new mesh from it
new_mesh = bpy.data.meshes.new_from_object(obj_eval)
print(new_mesh.vertices[0].groups[0].weight) # created mesh has groups and weight
# assign new mesh to the object
obj.data = new_mesh
print(obj.vertex_groups[:]) #vertex groups are gone
this example might be more linear
import bpy
# this piece used to preserve vertex groups but it doesn't
obj.data = bpy.data.meshes.new_from_object(obj)
This is what happens in current 3.0 builds.
This is what was happening in 2.93.1LTS and 3.0.0 on the 12th and prior.
Vgroup data was also part of the copy which was expected behavior. The removal of the data is the issue attempting to be outlined.
Em Eckx (masterxeon1001) updated the task description. (Show Details)
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Jul 24 2021, 3:45 AM
Can confirm. Possibly the culprit commit is rB3b6ee8cee7080af200e25e944fe30d310240e138 but will double check.
It looks like this function implements mesh copying from scratch.
I don't have time to test right now, but a quick fix is probably adding these lines to BKE_mesh_nomain_to_mesh:
BKE_defgroup_copy_list(&mesh_dst->vertex_group_names, &mesh_src->vertex_group_names);
mesh_dst->vertex_group_active_index = mesh_src->vertex_group_active_index;
Pratik Borhade (PratikPB2123) triaged this task as High priority.Jul 24 2021, 6:49 AM
Caused by rB3b6ee8cee708: Refactor: Move vertex group names to object data. Recent regression so marking this a high priority issue.
@Hans Goudey (HooglyBoogly) , sorry did not check your message. Will let you know after testing the change.
The issue persists in current builds.
Right, it hasn't been fixed yet. I will get to it tomorrow or Monday.
I have an issue too, projects that saved in 3.0 will lose their vertex group data if you try to open it in 2.93.X
