Radial repeat not work with front face only
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash: rB1b8d33b18c2f
Radial repeat does not work on all brushes when the front face only option is enabled.
  • Open attached .blend file
  • Check front faces only option and sculpt with radial z=8
Note this repetition does not work on all brushes.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jul 26 2021, 3:17 AM
Finaly this repetition dont work
Thanks for the report. Not sure I understand the issue. With front faces only option enabled it is possible for me to repeat the strokes.
Can you please check again with factory default settings? (File -> Defaults -> Load Factory settings)
Can you please add a short video to describe the problem?
I am in factory default settings.
I did the same test on version 2.79b and there is no problem.
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Aug 5 2021, 6:32 AM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from Developers.Aug 7 2021, 12:08 AM
From what I can see, the brushes that don't work are on faces that aren't in front.
So they're not "front faces".
Perhaps this behavior is intentional.
This is intended behaviour. It's supposed to only work on faces that are directed towards the view.
