Ubuntu 18
2.93 and prior
If a numpy array is passed for edges or faces in Mesh.from_pydata get following error:
blender-2.91.2-linux64/2.91/scripts/modules/bpy_types.py", line 488, in from_pydata
if edges or faces:
ValueError: The truth value of an array with more than one element is ambiguous. Use a.any() or a.all()can alleviate by typecasting to list eg:
faces = list(np.array([[0, 1, 2, 3]]))
but instead suggest a simple fix along lines of:
@@ -485,14 +485,14 @@
self.polygons.foreach_set("loop_start", loop_starts)
self.polygons.foreach_set("vertices", vertex_indices)
- if edges or faces:
+ if len(edges) or len(faces):
self.update(
# Needed to either:
# - Calculate edges that don't exist for polygons.
# - Assign edges to polygon loops.
- calc_edges=bool(faces),
+ calc_edges=bool(len(faces)),
# Flag loose edges.
- calc_edges_loose=bool(edges),
+ calc_edges_loose=bool(len(edges)),
@propertyExact steps for others to reproduce the error
- Run this script in the text editor:
import bpy
import numpy as np
from bpy_extras.object_utils import object_data_add
from mathutils import Vector
def add_object(context):
verts = [
Vector((-1, 1, 0)),
Vector((1, 1, 0)),
Vector((1, -1, 0)),
Vector((-1, -1, 0)),
edges = []
faces = [[0, 1, 2, 3]]
verts = np.array(verts)
edges = np.array(edges)
faces = np.array(faces)
mesh = bpy.data.meshes.new(name="New Object Mesh")
mesh.from_pydata(verts, edges, faces)
object_data_add(context, mesh, operator=None)
add_object(bpy.context)
