Hair particles do not appear correctly in the correct edit mode
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.41
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash: rB1b8d33b18c2f
I want to simulate hair particles to my character but he's not grieving at least not properly. (not even in Cycle GPU rendering)
it appears when I am in sculting mode, in vertice painting, in weight painting, but not in object mode, edition, texture paint, or particle edition.
I sculpted my pony with remesh on it, I created a proxy for not rowing when I work on it. and I wanted to work with the hair. without touching anything
Philipp Oeser (lichtwerk) renamed this task from les particule Hair n'aparaissent pas correctement dans les bon mode d'édition. to Hair particles do not appear correctly in the correct edit mode.Aug 3 2021, 1:46 PM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) closed this task as Archived.Aug 3 2021, 1:55 PM
This is due to the Edge Split modifier [which is before the particle modifier in the modifier stack].
By default, the particle modifier hair emission will be based on the "original" mesh [excluding modifers], but then the Edge Split modifier alters topology in a way that hair emission will not match anymore.
You can verify by disabling the Edge Split modifier.
Now you have two ways to work around this:
  • [1] move the Edge Split modifier before the particle modifier in the stack
  • [2] use the Use Modifier Stack in emission settings
So thx reporting, but this is expected behavior, will close.
