Outliner: None of context menu options are working in Sequencer mode and d&d doesn't work either
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 3.0.0 Alpha, branch: master (modified), commit date: 2021-08-10 10:07, hash: rBfe1740ae6a58
None of context menu options are working in Sequencer mode and d&d doesn't work either.
D&d from Outliner into the Sequencer was planned, but never implemented, and then forgotten about, I guess? Also, it is inconsistent that drag and drop from the Outline to the Sequencer doesn't work, when it is working from the Outliner to the 3D View.
D&D of data-blocks doesn't work either:
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Aug 12 2021, 5:27 PM
Part of the selection problem happens because the Sync Outliner Selection option is enabled.
The other part of the problem is that the Video Editor is not notified to update.
I didn't investigate the other issues mentioned.
It is highly advisable to only report one bug at a time, as we can only commit a fix per bug and the report needs to be linked to the commit.
Because of this, this report cannot be confirmed and forwarded to the developers :\
I can edit this one and create separate bug reports later.
I guess you could say in this case that the bug is: the implementation of the exposed features are left unfinished.
The second issue mentioned is actually a feature request that was listed in T77408: Continued Outliner Improvements Design but apparently discontinued.
So, thanks for the report, but the issue should be closed as the bug tracker is only for bugs and errors.
I suggest contacting the developer to know the reasons.
