Operating system: macOS-11.2.2-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.2.15
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-13 18:45, hash: rB5655b3d1c55a
Worked: Blender 2.92
When using the Extrude Region tool, you can drag on any of the axis handles to extrude along that axis. But in the latest version of Master, this is broken, because the larger 'free extrude' circle blocks the ability to hit and interact with the three axis-aligned handles:
This used to work correctly, where those three handles would always take precedence, so that users can always drag on those.
- Using the default startup, enter Edit Mode
- Enable the Extrude Region tool in the toolbar
- Switch to XYZ handles
- Make sure a face is selected
- Now try and drag the axis-aligned handles. it will extrude, but not along that axis. Instead, it will execute a free extrude, because the circle behind it takes the input.
Try this in Blender 2.9x and see that it works correctly.
