(Fields branch) Align rotation to vector node can cause a crash
Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 3.0.0 Alpha, branch: temp-geometry-nodes-fields-prototype, commit date: 2021-08-10 17:09, hash: rBc920b83b8456
In the fields prototype, blender will crash when setting the axis and pivot to the same value. It does not matter if the node is connected to anything.
Add a geometry nodes modifier to any mesh. Add an 'align rotation to vector' node. Set both the axis and pivot to 'X', 'Y', or 'Z'.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.EditedAug 20 2021, 5:52 PM
Thanks for the report. I can not reproduce on 3.0.0 (rB7d8c71e8003 and rB4c26bb02327f , 2021-08-09)
Please check again with daily builds: https://builder.blender.org/download/daily
Also Please provide the .blend file if crash happens on the latest 3.0.0 build.
Tested with the following node tree as described in the task:
First of all, I was referring to the experimental branch:
Second of all, the crash happens when the "Axis to align to the vector" and the "Pivot" are both set to the same axis.
(In the image, if I were to click LMB, blender would crash )
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Aug 21 2021, 12:14 PM
Hi, thanks for clarifying. I failed to notice the branch even though its clearly mentioned in task title and description.
I think the bugs from the experimental branches are not tracked on bug tracker.
Crash does not happen at least on master branch.
I did not know that, but I guess it makes sense. Would it then make more sense to directly message Jacques about the bug?
The prototype branch is no longer maintained. We started working on the actual fields implementation in a new branch today. Once that becomes a bit more mature we can accept bug reports.
