blender 2.93.0+ crashes on applying boolean modifier
Graphics card: AMD Radeon(TM) RX Vega 11 Graphics ATI Technologies Inc. 4.5.14742 Core Profile Context 21.8.1 27.20.22023.1004
Broken: version: 2.93.2 (starting from 2.93.0) branch: master, commit date: 2021-08-03 05:58, hash: rB1eb06de2607a
Worked: 2.92
blender crashes on applying boolean modifier
blender crashes on applying boolean modifier on some more complex objects
Crash log:
Blender 2.93.2, Commit date: 2021-08-03 05:58, Hash 1eb06de2607a
bpy.ops.object.delete(use_global=False, confirm=False)  # Operator
Deleted 1 object(s)  # Info
bpy.context.scene.hide_viewport = True  # Property
bpy.context.space_data.shading.type = 'WIREFRAME'  # Property
bpy.context.space_data.shading.type = 'SOLID'  # Property
bpy.ops.object.editmode_toggle()  # Operator
bpy.ops.mesh.select_all(action='INVERT')  # Operator
bpy.ops.mesh.select_less()  # Operator
bpy.ops.mesh.delete(type='VERT')  # Operator
bpy.ops.mesh.select_all(action='SELECT')  # Operator
bpy.ops.mesh.delete_loose()  # Operator
Removed: 48 vertices, 35 edges, 0 faces  # Info
bpy.ops.mesh.select_linked(delimit=set())  # Operator
bpy.ops.mesh.loop_multi_select(ring=False)  # Operator
bpy.ops.mesh.loop_multi_select(ring=True)  # Operator
bpy.ops.mesh.primitive_cube_add(size=2, enter_editmode=False, align='WORLD', location=(0, 0, 0), scale=(1, 1, 1))  # Operator
bpy.ops.transform.translate(value=(0.973817, 0, 0), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', constraint_axis=(True, False, False), mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', proportional_size=1, use_proportional_connected=False, use_proportional_projected=False, release_confirm=True)  # Operator
bpy.ops.transform.resize(value=(1, 1, 3.84949), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', constraint_axis=(False, False, True), mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', proportional_size=1, use_proportional_connected=False, use_proportional_projected=False, release_confirm=True)  # Operator
bpy.context.space_data.context = 'MODIFIER'  # Property
bpy.ops.object.modifier_add(type='BOOLEAN')  # Operator
bpy.ops.mesh.dissolve_mode(use_verts=True)  # Operator
Unable to open 'C:\Users\Me\AppData\Local\Temp\copybuffer.blend': No such file or directory  # Warning
No objects to paste  # Info
bpy.ops.mesh.primitive_cube_add(enter_editmode=False, align='WORLD', location=(0, 0, 0), scale=(1, 1, 1))  # Operator
bpy.ops.transform.resize(value=(1, 1, 3.91452), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', constraint_axis=(False, False, True), mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', proportional_size=1, use_proportional_connected=False, use_proportional_projected=False, release_confirm=True)  # Operator
bpy.ops.transform.translate(value=(-0.70476, -0, -0), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', constraint_axis=(True, False, False), mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', proportional_size=1, use_proportional_connected=False, use_proportional_projected=False, release_confirm=True)  # Operator
bpy.ops.transform.translate(value=(1.03815, 0, 0), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', constraint_axis=(True, False, False), mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', proportional_size=1, use_proportional_connected=False, use_proportional_projected=False, release_confirm=True)  # Operator
bpy.context.object.modifiers["Boolean"].object = bpy.data.objects["body"]  # Property
# backtrace
Exception Record:
ExceptionCode         : EXCEPTION_ACCESS_VIOLATION
Exception Address     : 0x00007FF78FA0E537
Exception Module      : blender.exe
Exception Flags       : 0x00000000
Exception Parameters  : 0x2
	Parameters[0] : 0x0000000000000000
	Parameters[1] : 0x0000000000000000
Stack trace:
blender.exe         :0x00007FF78FA0DF40  blender::meshintersect::meshes_to_imesh
blender.exe         :0x00007FF78FA0D100  blender::meshintersect::direct_mesh_boolean
blender.exe         :0x00007FF78B1228C0  exact_boolean_mesh
blender.exe         :0x00007FF78B121C70  modifyMesh
blender.exe         :0x00007FF78AF0BB30  modifier_modify_mesh_and_geometry_set
blender.exe         :0x00007FF78AF0A730  mesh_calc_modifiers
blender.exe         :0x00007FF78AF0A430  mesh_build_data
blender.exe         :0x00007FF78AF0CD20  makeDerivedMesh
blender.exe         :0x00007FF78AEE8E40  BKE_object_handle_data_update
blender.exe         :0x00007FF78AEE8B70  BKE_object_eval_uber_data
blender.exe         :0x00007FF78F4485B0  blender::deg::`anonymous namespace'::evaluate_node
blender.exe         :0x00007FF78F448560  blender::deg::`anonymous namespace'::deg_task_run_func
tbb.dll             :0x00007FFEAB5F54A0  tbb::interface7::internal::isolate_within_arena
blender.exe         :0x00007FF78F8CDE50  tbb::internal::function_task<Task>::execute
tbb.dll             :0x00007FFEAB6054D0  tbb::recursive_mutex::scoped_lock::internal_try_acquire
tbb.dll             :0x00007FFEAB5FAA50  tbb::task_scheduler_init::terminate
tbb.dll             :0x00007FFEAB6036F0  tbb::thread_bound_filter::try_process_item
ucrtbase.dll        :0x00007FFF01461B20  configthreadlocale
KERNEL32.DLL        :0x00007FFF02067020  BaseThreadInitThunk
ntdll.dll           :0x00007FFF037C2630  RtlUserThreadStart
Threads:
Thread : 000031d4
ntdll.dll           :0x00007FFF0380D6D0  ZwYieldExecution
blender.exe         :0x00007FF78B181EE0  tbb::internal::task_group_base::wait
blender.exe         :0x00007FF78F4480F0  blender::deg::deg_evaluate_on_refresh
blender.exe         :0x00007FF78ADD0680  scene_graph_update_tagged
blender.exe         :0x00007FF78AF8A9C0  wm_event_do_notifiers
blender.exe         :0x00007FF78AF74AA0  WM_main
blender.exe         :0x00007FF78AC31C60  main
blender.exe         :0x00007FF78F9EB8A8  __scrt_common_main_seh
Thread : 00002f10
ntdll.dll           :0x00007FFF0380CE90  NtWaitForSingleObject
KERNELBASE.dll      :0x00007FFF00FF1940  WaitForSingleObjectEx
blender.exe         :0x00007FF78EFED860  IlmThread_2_5::Semaphore::wait
blender.exe         :0x00007FF78EFED030  IlmThread_2_5::ThreadPool::numThreads
blender.exe         :0x00007FF78EFEDCD0  std::_LaunchPad<std::unique_ptr<std::tuple<void (__cdecl IlmThread_2_5::Thread::*)(void) __ptr64,Il
blender.exe         :0x00007FF78DB2BF00  std::_Pad::_Call_func
Thread : 00002ae0
Thread : 00002be8
Thread : 00003788
Thread : 000017ac
Thread : 00002820
Thread : 000037d4
Thread : 00000c54
Thread : 00002440
Thread : 000037c8
Thread : 00003c58
Thread : 00002cc4
Thread : 0000259c
Thread : 000043ac
Thread : 000025a8
Thread : 00001e48
atio6axx.dll        :0x00007FFEBEB14420  DrvPresentBuffers
Thread : 00003bbc
Thread : 00004074
Thread : 00002c54
Thread : 00003504
ntdll.dll           :0x00007FFF03810860  ZwWaitForWorkViaWorkerFactory
ntdll.dll           :0x00007FFF037C2680  TpReleaseCleanupGroupMembers
Loaded Modules :
0x00007FF78AB00000 2.9.3.0              blender.exe C:\Program Files\Blender Foundation\Blender 2.93\blender.pdb
0x00007FFF03770000 10.0.19041.1110      ntdll.dll
0x00007FFF02050000 10.0.19041.1151      KERNEL32.DLL
0x00007FFF00FD0000 10.0.19041.1151      KERNELBASE.dll
0x00007FFF02EF0000 10.0.19041.1151      USER32.dll
0x00007FFF00EA0000 10.0.19041.1151      win32u.dll
0x00007FFEAB5F0000 2020.2.0.0           tbb.dll
0x00007FFF027F0000 10.0.19041.746       GDI32.dll
0x00007FFF01330000 10.0.19041.1110      gdi32full.dll
0x00007FFF01730000 10.0.19041.789       msvcp_win.dll
0x00007FFF01440000 10.0.19041.789       ucrtbase.dll
0x00007FFF01910000 10.0.19041.1151      SHELL32.dll
0x00007FFEAB130000 14.28.29910.0        MSVCP140.dll
0x00007FFF00ED0000 10.0.19041.1151      CFGMGR32.dll
0x00007FFF02B30000 10.0.19041.546       WS2_32.dll
0x00007FFEDBD40000 14.28.29910.0        VCRUNTIME140.dll
0x00007FFF03160000 10.0.19041.1081      RPCRT4.dll
0x00007FFF02A80000 10.0.19041.1052      ADVAPI32.dll
0x00007FFF02110000 7.0.19041.546        msvcrt.dll
0x00007FFF03290000 10.0.19041.906       sechost.dll
0x00007FFF028A0000 10.0.19041.746       ole32.dll
0x00007FFF03340000 10.0.19041.1081      combase.dll
0x00007FFF03330000 10.0.19041.546       PSAPI.DLL
0x00007FFF02E80000 10.0.19041.1023      SHLWAPI.dll
0x00007FFF027A0000 10.0.19041.546       IMM32.dll
0x00007FFEA5A40000 8.0.1.0              openvdb.dll
0x00007FFECC9D0000 10.0.19041.1081      OPENGL32.dll
0x00007FFEA5530000 3.9.2150.1013        python39.dll
0x00007FFE83860000 58.54.100.0          avcodec-58.dll
0x00007FFEA51F0000 58.29.100.0          avformat-58.dll
0x00007FFEAB4C0000 56.31.100.0          avutil-56.dll
0x00007FFEAF620000 58.8.100.0           avdevice-58.dll
0x00007FFF03090000 10.0.19041.985       OLEAUT32.dll
0x00007FFF01300000 10.0.19041.1023      bcrypt.dll
0x00007FFEAB420000 5.5.100.0            swscale-5.dll
0x0000000070440000 1.0.28.0             libsndfile-1.dll
0x00007FFEAB220000 1.20.1.0             OpenAL32.dll
0x00007FFEA50C0000 2.0.12.0             SDL2.dll
0x00007FFF02320000 10.0.19041.1151      SETUPAPI.dll
0x000000006ACC0000                      libgmp-10.dll
0x00007FFEDFC20000 2020.2.0.0           tbbmalloc_proxy.dll
0x00007FFEDE9A0000 14.28.29910.0        VCRUNTIME140_1.dll
0x00007FFEEAA60000 6.10.19041.1110      COMCTL32.dll
0x00007FFEAEEB0000 10.0.19041.1         AVIFIL32.dll
0x00007FFEF8F00000 10.0.19041.546       VERSION.dll
0x00007FFEFA320000 10.0.19041.867       dbghelp.dll
0x0000000070680000                      libfftw3-3.dll
0x00007FFED4330000 10.0.19041.1081      GLU32.dll
0x00007FFEACFF0000 3.5.100.0            swresample-3.dll
0x00007FFEDAB10000 10.0.19041.1         AVICAP32.dll
0x00007FFEEDE80000 10.0.19041.546       Secur32.dll
0x00007FFEF8B50000 10.0.19041.546       WINMM.dll
0x00007FFEAB3E0000 2020.2.0.0           tbbmalloc.dll
0x00007FFEAB3B0000 10.0.19041.1         MSVFW32.dll
0x00007FFED74F0000 10.0.19041.1         MSACM32.dll
0x00007FFEF4190000 10.0.19041.1         winmmbase.dll
0x00007FFF00D90000 10.0.19041.906       SSPICLI.DLL
0x00007FFF021B0000 10.0.19041.1023      shcore.dll
0x00007FFEFEDD0000 10.0.19041.546       kernel.appcore.dll
0x00007FFEFEFD0000 10.0.19041.1151      windows.storage.dll
0x00007FFF00880000 10.0.19041.662       Wldp.dll
0x00007FFEFE8F0000 10.0.19041.1081      uxtheme.dll
0x00007FFF016A0000 10.0.19041.1023      bcryptPrimitives.dll
0x00007FFF00DE0000 10.0.19041.844       profapi.dll
0x00007FFF029D0000 2001.12.10941.16384  clbcatq.dll
0x00007FFEFBB80000 10.0.19041.1023      MMDevApi.dll
0x00007FFF00C40000 10.0.19041.1151      DEVOBJ.dll
0x00007FFEFBC20000 10.0.19041.1023      AUDIOSES.DLL
0x00007FFF00A30000 10.0.19041.546       powrprof.dll
0x00007FFF00A10000                      UMPDC.dll
0x00007FFF02D60000 10.0.19041.1081      MSCTF.dll
0x00007FFEE8240000 10.0.19041.1151      dataexchange.dll
0x00007FFEFCF90000 10.0.19041.746       d3d11.dll
0x00007FFEFDC20000 10.0.19041.1023      dcomp.dll
0x00007FFEFF7A0000 10.0.19041.964       dxgi.dll
0x00007FFEFB710000 10.0.19041.964       twinapi.appcore.dll
0x00007FFEFAED0000 10.0.19041.1110      AppXDeploymentClient.dll
0x00007FFECC160000 27.20.22023.1004     atig6pxx.dll
0x00007FFEBE220000 27.20.22023.1004     atio6axx.dll
0x00007FFEE85F0000 10.0.19041.1         dxva2.dll
0x00007FFEFEAE0000 10.0.19041.746       dwmapi.dll
0x00007FFEC7A40000 27.20.22023.1004     atig6txx.dll
0x00007FFECC290000 27.20.22023.1004     atiadlxx.dll
0x00007FFEE6E00000 10.0.19041.906       pdh.dll
0x00007FFEFC7D0000 7.0.19041.1023       PROPSYS.dll
0x00007FFF012A0000 10.0.19041.1151      WINTRUST.dll
0x00000208DB6E0000 10.0.19041.844       CRYPT32.dll
0x00007FFF00A80000 10.0.19041.546       MSASN1.dll
0x00007FFEF8F70000 10.0.19041.546       dxcore.dll
0x00007FFEEEFE0000 10.0.19041.1151      textinputframework.dll
0x00007FFEFE4F0000 10.0.19041.746       CoreMessaging.dll
0x00007FFEFDE10000 10.0.19041.546       CoreUIComponents.dll
0x00007FFEFFBA0000 10.0.19041.546       ntmarta.dll
0x00007FFEFCE30000 10.0.19041.1081      wintypes.dll
0x00007FFEE7E70000 10.0.19041.1023      explorerframe.dll
0x00007FFF007E0000 10.0.19041.546       CRYPTSP.dll
0x00007FFEFFF10000 10.0.19041.1052      rsaenh.dll
0x00007FFF008F0000 10.0.19041.546       CRYPTBASE.dll
# Python backtrace
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Aug 23 2021, 3:43 PM
Hi and thx reporting!
Could you share a blend file where this happens?
Philipp Oeser (lichtwerk) closed this task as Archived.Sep 2 2021, 11:41 AM
