Add object tool doesn't align to the surface when in edit mode
Graphics card: NVIDIA GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-23 22:50, hash: rBede1ce6e9a5b
When using Add object tool in object mode, the objects are snapped to the normal of the mesh under the cursor.
However, once you try doing the same in edit mode, object go right through, not aligning to anything in particular
See video for example:
  1. Open new file
  2. Choose "Add object" tool and see the preview cursor - it aligns to the surface
  3. Pick an active object
  4. Go to edit mode
  5. Choose "Add object" tool
  6. Now the tool behaves differently and is not useful
Hans Goudey (HooglyBoogly) changed the task status from Needs Triage to Needs Information from User.Aug 24 2021, 10:50 PM
Thanks for the report. It looks like you're using an older build (about a month old). Could you check with the most recent build?
Ramil Roosileht (Limarest) claimed this task.
The bug seems to be fixed in the latest master. I guess I'll close it then
