Material VX crash
Graphics card: Intel(R) HD Graphics 520 Intel 4.5.0 - Build 27.20.100.8854
Broken: version: 2.93.2, branch: master, commit date: 2021-08-03 05:58, hash: rB1eb06de2607a
Addon Information
Name: Material Library (0, 6, 0)
Author: Mackraken
I have used the Material VX library for years but recently it just crashes any time I try to load it. Are than any known conflicts with other add-ons?
happening with me as of feb 2022, the App freezes and goes not responding when i try to pick "Sample Materials" or "Templates" from "Select a library" Tab
Graphics card: NVIDIA GeForce GTX 1060 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: rBf1cca3055776
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 22 2022, 4:31 PM
Can you attach the crash log written by Blender when it crashes? https://docs.blender.org/manual/en/latest/troubleshooting/crash.html
You could try disabling other add-ons and checking if any of them causes a conflict.
Are you talking about enabling the add-on or loading some material from it?
I'm not finding any crash log in /tmp folder as it is not Crashing just becoming unresponsive forever until i force close it
I tried turning off other ad-ons, same thing
The add-on is already enabled and i was able to use it few weeks earlier just fine, only now it freezes when i try to load some materials from it yes, in fact Opening Sample Materials menu causing it, before i can load or view any material.
@Mohammad Tareq (MTKing) Okay. Your issue seems different from the original report then. But I have seen some similar reports to what you are describing, so I will get back to you later.
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
Omar Emara (OmarSquircleArt) claimed this task.
