Material properties surface selection UI does not filter out hidden node groups
Confirmed, LowPublicBUG
Operating system: Windows 10.0.19042 Build 19042
Graphics card: AMD Radeon RX570
Broken: 2.93.0 Alpha (hash: 3494946560c2)
nodeitems_builtins contains a function used for listing node groups which filters out "hidden" groups - denoted by the name starting with a period.
https://github.com/blender/blender/blob/2f7258d618a2a38fc982a9e0d0d7dd3cbc95ab3a/release/scripts/startup/nodeitems_builtins.py#L118
This prevents those groups showing up in the node editor when adding a group node, and is very useful for custom node groups, especially in the context of auto generation by an addon via ShaderNodeCustomGroup. However, there exists another UI for selecting node groups which does not do the same filtering: in the material properties panel by clicking "Surface". Custom node groups which should be hidden clutter the box.
The guilty function appears to be uiTemplateNodeView.
  1. Add a mesh and node based material for that mesh
  2. Edit the nodes and create a node group
  3. See that the node group shows up in the Add > Group menu
  4. Rename the node group .HiddenNodeGroup or similar
  5. See that the node group is hidden in the Add > Group menu [first image]
  6. See that the node group still shows up in the Properties > Material > Surface dropdown [second image]
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Confirmed.Mar 23 2022, 7:21 AM
It seems the behavior you want is the intended behavior discussed in D4370. So I will mark this confirmed.
Dalai Felinto (dfelinto) closed this task as Archived.May 9 2022, 3:44 PM
This is not a bug. The ability to hide built-in nodes are not exposed to end-users.
@Dalai Felinto (dfelinto) I think you've misunderstood - this ticket is not about hiding built-in nodes. It's about hiding user defined node groups which have been given a name that makes them hidden everywhere else in the UI, but not this one dropdown box. This bug is a consistency issue.
Dalai Felinto (dfelinto) reopened this task as Confirmed.May 10 2022, 3:32 PM
Dalai Felinto (dfelinto) triaged this task as Low priority.
Dalai Felinto (dfelinto) changed the subtype of this task from "Report" to "Bug".
Ok. I guess it makes sense to be consistent. Lowering its priority, but patches are welcome if someone wants to fix this.
