2.93 crashes
Date/Time: 2021-08-31 16:20:31.719 +0000
OS Version: Mac OS X 10.14.6 (18G9216)
Graphics card: Intel Iris Pro 1536 MB
Broken: (example: 2.93,
Crashes when I go to: Edit-Menu Searsch
Exact steps for others to reproduce the error Just open blender 2.93 and go to: Edit menu search
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Sep 1 2021, 4:28 AM
Does this happen when you click on File > Defaults > Load Factory Settings?
Answer: No, when I load factory settings everything is fine.
This is likely an Addon causing this.
Could you try to enable your Addons one-by-one and report back if any of these are causing the issue?
When I went to File>Delfaults>Load Factory Settings, everything went fine.
Then I reopened the file I am working on and the problem was still there.
Then I un-checked the add-ons one by one, saved preferences each time - and the problem is still there.
I loaded factory preferences in the Preferences and - the problem is still there.
Then, I opened my file after: File>Delfaults>Load Factory Settings, then I disabled all add-ons, saved preferences and - the problem is still there.
So, if I have no add-ons enabled an add-on can hardly be the cause, right?
Finally, I went to 3.0.0. alpha, copied my model from 2.93 and resumed working and am able to use the: Edit>Menu Search and everything is fine.
Process: Blender [5764]
Path: /Applications/Blender 3.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.93.0 (2.93.0 2021-04-07)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [5764]
User ID: 501
Date/Time: 2021-09-01 07:49:15.276 +0000
Report Version: 12
Anonymous UUID: C31DE609-4A32-CCD1-DA4D-E980F0134E5F
Time Awake Since Boot: 83000 seconds
System Integrity Protection: enabled
Crashed Thread: 1
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [5764]
Thread 0:: Dispatch queue: com.apple.main-thread
0 org.blenderfoundation.blender 0x000000010d2fd203 rna_Area_ui_type_itemf + 51
1 org.blenderfoundation.blender 0x000000010d1bf346 RNA_property_enum_items + 150
2 org.blenderfoundation.blender 0x000000010d74172d UI_but_func_menu_search + 589
3 org.blenderfoundation.blender 0x000000010ce0dc1e wm_block_search_menu + 190
4 org.blenderfoundation.blender 0x000000010d73a1dc ui_popup_block_refresh + 108
5 org.blenderfoundation.blender 0x000000010d73b2ca ui_popup_block_create + 330
6 org.blenderfoundation.blender 0x000000010d7392d2 UI_popup_block_invoke_ex + 66
7 org.blenderfoundation.blender 0x000000010ce0db38 wm_search_menu_invoke + 184
8 org.blenderfoundation.blender 0x000000010cdf2b89 wm_operator_invoke + 521
9 org.blenderfoundation.blender 0x000000010cded1bc wm_operator_call_internal + 284
10 org.blenderfoundation.blender 0x000000010cded6d0 WM_operator_name_call_ptr + 32
11 org.blenderfoundation.blender 0x000000010d71104b ui_apply_but_funcs_after + 299
12 org.blenderfoundation.blender 0x000000010d70d7c3 ui_handler_region_menu + 387
13 org.blenderfoundation.blender 0x000000010cdf3aea wm_handlers_do_intern + 2554
14 org.blenderfoundation.blender 0x000000010cdeee90 wm_handlers_do + 32
15 org.blenderfoundation.blender 0x000000010cdee2f3 wm_event_do_handlers + 1507
16 org.blenderfoundation.blender 0x000000010cde70e0 WM_main + 32
17 org.blenderfoundation.blender 0x000000010c8d709b main + 907
18 libdyld.dylib 0x00007fff5b7bb3d5 start + 1
Thread 1 Crashed:
0 libsystem_kernel.dylib 0x00007fff5b8f0256 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff5b76ebd9 _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff5b76f39f _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x0000000113b2360f IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
4 org.blenderfoundation.blender 0x0000000113b2209e void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
6 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
7 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
0 libsystem_pthread.dylib 0x00007fff5b9ae3f0 start_wqthread + 0
Thread 10:
Thread 11:
Thread 12:
Thread 13:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff5b8f021a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff5b8f0768 mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff2f293dba HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x00007fff2f293d2f HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff2f29027f HALC_ProxyIOContext::IOWorkLoop() + 1017
5 com.apple.audio.CoreAudio 0x00007fff2f28fcd4 HALC_ProxyIOContext::IOThreadEntry(void*) + 122
6 com.apple.audio.CoreAudio 0x00007fff2f28f836 HALB_IOThread::Entry(void*) + 72
7 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
8 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
9 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 14:
1 org.blenderfoundation.blender 0x000000010cddde98 tbb::internal::rml::private_worker::run() + 344
2 org.blenderfoundation.blender 0x000000010cdddd39 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
4 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
5 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
0 libsystem_kernel.dylib 0x00007fff5b8f41e6 __accept + 10
1 _socket.cpython-39-darwin.so 0x000000012ae661b8 sock_accept_impl + 24
2 _socket.cpython-39-darwin.so 0x000000012ae6669f sock_call_ex + 591
3 _socket.cpython-39-darwin.so 0x000000012ae63fa0 sock_accept + 144
4 org.blenderfoundation.blender 0x0000000114141abb method_vectorcall_NOARGS + 139
5 org.blenderfoundation.blender 0x000000011422031b call_function + 411
6 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
7 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
8 org.blenderfoundation.blender 0x000000011422031b call_function + 411
9 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
10 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
11 org.blenderfoundation.blender 0x000000011422031b call_function + 411
12 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
13 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
14 org.blenderfoundation.blender 0x000000011422031b call_function + 411
15 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
16 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
17 org.blenderfoundation.blender 0x000000011413b522 method_vectorcall + 370
18 org.blenderfoundation.blender 0x00000001142c0cc6 t_bootstrap + 70
19 org.blenderfoundation.blender 0x0000000114272549 pythread_wrapper + 25
20 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
21 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
22 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 22:
0 libsystem_kernel.dylib 0x00007fff5b8f7616 __select + 10
1 org.blenderfoundation.blender 0x00000001142be3fc time_sleep + 124
2 org.blenderfoundation.blender 0x00000001141796c0 cfunction_vectorcall_O + 288
3 org.blenderfoundation.blender 0x000000011422031b call_function + 411
4 org.blenderfoundation.blender 0x000000011421d3a6 _PyEval_EvalFrameDefault + 27654
5 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
6 org.blenderfoundation.blender 0x000000011422031b call_function + 411
7 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
8 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
9 org.blenderfoundation.blender 0x000000011422031b call_function + 411
10 org.blenderfoundation.blender 0x000000011421d389 _PyEval_EvalFrameDefault + 27625
11 org.blenderfoundation.blender 0x00000001141390b5 function_code_fastcall + 229
12 org.blenderfoundation.blender 0x000000011413b522 method_vectorcall + 370
13 org.blenderfoundation.blender 0x00000001142c0cc6 t_bootstrap + 70
14 org.blenderfoundation.blender 0x0000000114272549 pythread_wrapper + 25
15 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
16 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
17 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 23:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff2f824e0e CFRunLoopServiceMachPort + 328
3 com.apple.CoreFoundation 0x00007fff2f82437c
CFRunLoopRun + 1612
4 com.apple.CoreFoundation 0x00007fff2f823ade CFRunLoopRunSpecific + 455
5 com.apple.AppKit 0x00007fff2ce214a2 _NSEventThread + 175
6 libsystem_pthread.dylib 0x00007fff5b9af2eb _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff5b9b2249 _pthread_start + 66
8 libsystem_pthread.dylib 0x00007fff5b9ae40d thread_start + 13
Thread 24:
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000e  rbx: 0x000060000024a200  rcx: 0x000070000a207e68  rdx: 0x0000000000000028
rdi: 0x0000000000001703  rsi: 0x0000000000000003  rbp: 0x000070000a207e80  rsp: 0x000070000a207e68
 r8: 0x0000000000000e03   r9: 0x0000000000000000  r10: 0x0000000000002903  r11: 0x0000000000000246
r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x000060000024a200  r15: 0xffffffffffffffff
rip: 0x00007fff5b8f0256  rfl: 0x0000000000000246  cr2: 0x000070000a30df78
Logical CPU: 0
Error Code: 0x01000024
Trap Number: 133
Binary Images:
   0x10c771000 -        0x11852cf47 +org.blenderfoundation.blender (2.93.0 - 2.93.0 2021-04-07) <44D82ECA-D4B2-3125-996C-12D273EB27DC> /Applications/Blender 3.app/Contents/MacOS/Blender
   0x11eeec000 -        0x11ef58ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender 3.app/Contents/Resources/lib/libomp.dylib
   0x11f507000 -        0x11f69cff7  com.apple.audio.units.Components (1.14 - 1.14) <1F83F9B9-BEEC-35DE-8DD8-A8A83A8713ED> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
   0x12111e000 -        0x121122ffb  com.apple.audio.AppleHDAHALPlugIn (282.54 - 282.54) <207D25F0-B094-3569-AA6D-09B4EDD72861> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
   0x121128000 -        0x12117afff +com.usb-audio.hal (3.3.11) <6EAAA5DD-CFA5-3C13-B529-770A2080FEF4> /Library/Audio/Plug-Ins/HAL/usb-audio.com.plugin/Contents/MacOS/usb-audio.com
   0x123c92000 -        0x123c95047  libobjc-trampolines.dylib (756.2) <5795A048-3940-3801-90CE-33D1B1AF81F4> /usr/lib/libobjc-trampolines.dylib
   0x127bce000 -        0x127bd1fff +_heapq.cpython-39-darwin.so (0) <39FBF3FE-B287-3DE1-9C22-E65F7DE3FBD6> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
   0x127be3000 -        0x127c4d70f  dyld (655.1.1) <AF217C8D-5AF1-34FF-8643-A3FB0537E9D0> /usr/lib/dyld
   0x12a6f2000 -        0x12a6fdff3 +math.cpython-39-darwin.so (0) <B182812A-68AA-35BD-A8E8-D26E6BDB8C3F> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
   0x12ae0c000 -        0x12ae13fff +_json.cpython-39-darwin.so (0) <ACB3C18C-E080-3C95-8420-DAE93E2D5E99> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_json.cpython-39-darwin.so
   0x12ae60000 -        0x12ae6fff7 +_socket.cpython-39-darwin.so (0) <B1F1427E-EC5E-35BF-8595-3AB7F81B8BFA> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
   0x12ae80000 -        0x12ae87fff +select.cpython-39-darwin.so (0) <9F931F33-6B72-314B-9365-C443F0E411CE> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
   0x12ae94000 -        0x12ae9bfff +array.cpython-39-darwin.so (0) <C6EAB41B-E104-3EF6-923E-5279F64BB2AE> /Applications/Blender 3.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
0x7fff27a14000 -     0x7fff27f26fff  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (12.10.30 - 12.1.0) <D1B61F75-BED6-3918-8D3D-5E4AA4E7D91A> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x7fff27f27000 -     0x7fff27fb8ff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (12.10.30 - 12.1.0) <63BC7B71-9CB4-3F20-975D-27C06E5FA020> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x7fff2bbcb000 -     0x7fff2bbcbfff  com.apple.Accelerate (1.11 - Accelerate 1.11) <762942CB-CFC9-3A0C-9645-A56523A06426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2bbcc000 -     0x7fff2bbe2ff7  libCGInterfaces.dylib (506.22) <1B6C92D9-F4B8-37BA-9635-94C4A56098CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff2bbe3000 -     0x7fff2c27cfef  com.apple.vImage (8.1 - ???) <53FA3611-894E-3158-A654-FBD2F70998FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2c27d000 -     0x7fff2c4f6ff3  libBLAS.dylib (1243.200.4) <417CA0FC-B6CB-3FB3-ACBC-8914E3F62D20> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2c4f7000 -     0x7fff2c569ffb  libBNNS.dylib (38.250.1) <538D12A2-9B9D-3E22-9896-F90F6E69C06E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2c56a000 -     0x7fff2c913ff3  libLAPACK.dylib (1243.200.4) <92175DF4-863A-3780-909A-A3E5C410F2E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2c914000 -     0x7fff2c929feb  libLinearAlgebra.dylib (1243.200.4) <CB671EE6-DEA1-391C-9B2B-AA09A46B4D7A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2c92a000 -     0x7fff2c92fff3  libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2c930000 -     0x7fff2c9acff3  libSparse.dylib (79.200.5) <E78B33D3-672A-3C53-B512-D3DDB2E9AC8D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2c9ad000 -     0x7fff2c9c0fe3  libSparseBLAS.dylib (1243.200.4) <E9243341-DB77-37C1-97C5-3DFA00DD70FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2c9c1000 -     0x7fff2cba8ff7  libvDSP.dylib (671.250.4) <7B110627-A9C1-3FB7-A077-0C7741BA25D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2cba9000 -     0x7fff2cc5cff7  libvMisc.dylib (671.250.4) <D5BA4812-BFFC-3CD0-B382-905CD8555DA6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2cc5d000 -     0x7fff2cc5dfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <74288115-EF61-30B6-843F-0593B31D4929> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2cdff000 -     0x7fff2dbb4ffb  com.apple.AppKit (6.9 - 1671.60.109) <13EBDF4A-1B54-36F6-BC85-E23526B163F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2dc06000 -     0x7fff2dc06fff  com.apple.ApplicationServices (50.1 - 50.1) <89FD39C7-7065-32AC-92A5-1A39269C8420> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2dc07000 -     0x7fff2dc72fff  com.apple.ApplicationServices.ATS (377 - 453.11.2.2) <A258DA73-114B-3102-A056-4AAAD3CEB9DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2dd0b000 -     0x7fff2de22fff  libFontParser.dylib (228.6.2.12) <247BA958-137F-3763-A9F3-9B9FFBDCB3D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff2de23000 -     0x7fff2de65fff  libFontRegistry.dylib (228.12.2.4) <6DDE44EC-FF6B-3893-9209-45E0955ABDD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2debf000 -     0x7fff2def1fff  libTrueTypeScaler.dylib (228.6.2.12) <30A5AE06-93B9-3BA4-B867-A0BF145E4115> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff2df56000 -     0x7fff2df5aff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <E8E9342C-47EB-359D-A373-554AC19B174A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2dff5000 -     0x7fff2e047ff7  com.apple.HIServices (1.22 - 628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2e048000 -     0x7fff2e057fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <F5617A2A-FEA6-3832-B5BA-C2111B98786F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2e058000 -     0x7fff2e0a1ff7  com.apple.print.framework.PrintCore (14.7 - 503.8) <E1D0FCBC-155E-372E-A90F-4A20B94FC114> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2e0a2000 -     0x7fff2e0dbff7  com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2e0dc000 -     0x7fff2e0e8fff  com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <5E7B9BD4-122B-3012-A044-3259C97E7509> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2e0e9000 -     0x7fff2e360ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <4E6EAEDA-CC0F-384A-8563-7CAE1D976503> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2e362000 -     0x7fff2e362fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <1CD6D278-2BC1-3BB9-B692-08120882C3C5> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2e6bb000 -     0x7fff2ea5dfff  com.apple.CFNetwork (978.6 - 978.6) <F6AC3859-B6F9-3212-A357-54AA096DAA9E> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2ea72000 -     0x7fff2ea72fff  com.apple.Carbon (158 - 158) <2B882FDA-8576-3986-8E09-F1A4E5FE48D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff2ea73000 -     0x7fff2ea76ffb  com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff2ea77000 -     0x7fff2ed6efff  com.apple.HIToolbox (2.1.1 - 918.7) <88D7F19C-8C9D-384B-BAB5-8205CA282F2C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2ed6f000 -     0x7fff2ed72ff3  com.apple.help (1.3.8 - 66) <A08517EB-8958-36C9-AEE0-1A8FEEACBE3F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff2ed73000 -     0x7fff2ed78ff7  com.apple.ImageCapture (9.0 - 1534.2) <DB063E87-ED8F-3E4E-A7E2-A6B45FA73EF7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff2ed79000 -     0x7fff2ee0eff3  com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2ee0f000 -     0x7fff2ee27ff7  com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff2ee47000 -     0x7fff2ee48ff7  com.apple.print.framework.Print (14.2 - 267.4) <A7A9D2A0-D4E0-35EF-A0F7-50521F707C33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff2ee49000 -     0x7fff2ee4bff7  com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff2ee4c000 -     0x7fff2ee52ff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2ef74000 -     0x7fff2ef74fff  com.apple.Cocoa (6.11 - 23) <511C680D-A2D3-3C10-A67D-06E812525FE7> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff2ef82000 -     0x7fff2f0d1ff7  com.apple.ColorSync (4.13.0 - 3345.6) <356BA478-76DE-3087-86BE-5E884276AB83> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff2f25d000 -     0x7fff2f2e3fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <E6E4A58D-9BAE-30B1-856E-E1332B98E9ED> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2f347000 -     0x7fff2f371ffb  com.apple.CoreBluetooth (1.0 - 1) <4F2DDEF0-1F92-384B-8CDA-4958725D0A8E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff2f372000 -     0x7fff2f6f7fef  com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff2f6f8000 -     0x7fff2f7e8ff7  com.apple.CoreDisplay (101.3 - 110.18) <6DD41271-E145-3E99-9D49-7CC8AC1C65B6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2f7e9000 -     0x7fff2fc2ffff  com.apple.CoreFoundation (6.9 - 1575.405) <D1BE2B09-17CD-35FE-A165-43F8328E77A8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2fc31000 -     0x7fff302c1fe7  com.apple.CoreGraphics (2.0 - 1265.13) <C4238967-56E7-3AE5-A3F4-1A878EB5FFD8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff302c3000 -     0x7fff305e3fff  com.apple.CoreImage (14.4.0 - 750.0.140) <11026E39-D2FF-3CF6-8ACE-7BA293F9853E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff30a41000 -     0x7fff30a41fff  com.apple.CoreServices (946 - 946) <C2BA6E71-CDF9-314B-8E10-D53C0180720F> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff30a42000 -     0x7fff30abeff7  com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff30abf000 -     0x7fff30d96fff  com.apple.CoreServices.CarbonCore (1178.33 - 1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff30d97000 -     0x7fff30ddfff7  com.apple.DictionaryServices (1.2 - 284.16.4) <746EB200-DC51-30AE-9CBC-608A7B4CC8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff30de0000 -     0x7fff30de8ffb  com.apple.CoreServices.FSEvents (1239.200.13 - 1239.200.13) <5913F08D-4AA2-3200-B998-012E6A19A66D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff30de9000 -     0x7fff30f9aff7  com.apple.LaunchServices (946 - 946) <A0C91634-9410-38E8-BC11-7A5A369E6BA5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff30f9b000 -     0x7fff31039ff7  com.apple.Metadata (10.7.0 - 1191.58) <89DA10B4-5695-3FD9-A920-C34C33957868> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3103a000 -     0x7fff31084ff7  com.apple.CoreServices.OSServices (946 - 946) <20C4EEF8-D5AC-39A0-9B4A-78F88E3EFBCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff31085000 -     0x7fff310ecff7  com.apple.SearchKit (1.4.0 - 1.4.0) <DA08AA6F-A6F1-36C0-87F4-E26294E51A3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff310ed000 -     0x7fff3110eff3  com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff31419000 -     0x7fff3157dff3  com.apple.CoreText (352.0 - 584.26.3.8) <403650AA-266C-36C0-A2C3-B38D91B5FA57> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3157e000 -     0x7fff315beff3  com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff315bf000 -     0x7fff3164efff  com.apple.framework.CoreWLAN (13.0 - 1375.2) <A476486C-B863-3941-BAE6-A78BDFED4A3B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff318a5000 -     0x7fff318aaffb  com.apple.DiskArbitration (2.7 - 2.7) <04909487-FEF7-3AB9-B8B6-A5FB3DE938BE> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff31a6e000 -     0x7fff31a70ff3  com.apple.ForceFeedback (1.0.6 - 1.0.6) <205B0C3E-4E8D-3347-A993-469F06ABBFF9> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff31a71000 -     0x7fff31e1fffb  com.apple.Foundation (6.9 - 1575.405) <1177B3CF-C81D-3982-BCC2-819731D99F01> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff31e8e000 -     0x7fff31ebdffb  com.apple.GSS (4.0 - 2.0) <4B72210D-63E7-34C9-BFD4-48E11F857EE1> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff31fbd000 -     0x7fff320c7fff  com.apple.Bluetooth (6.0.14 - 6.0.14d12) <0904E4FC-DE05-3B78-BD49-832A5AC2967D> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3212a000 -     0x7fff321b9fff  com.apple.framework.IOKit (2.0.2 - 1483.260.5) <C00462C2-9CF3-3E3E-BD1E-B57AF6AB562E> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff321bb000 -     0x7fff321caffb  com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff3221e000 -     0x7fff323abff7  com.apple.ImageIO.framework (3.3.0 - 1850.2.14) <A32566AF-0155-3A50-BA23-0288D3F5D35E> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff323ac000 -     0x7fff323b0ffb  libGIF.dylib (1850.2.14) <E0A55FF4-0EA2-38DE-9BC3-CDDA18855E0B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff323b1000 -     0x7fff3248dff7  libJP2.dylib (1850.2.14) <0B1933D0-EFCE-3A6E-94AC-6E25C8B9A34B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff3248e000 -     0x7fff324b3feb  libJPEG.dylib (1850.2.14) <2864EF55-B068-3634-865A-C71858CC396D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff32789000 -     0x7fff327affeb  libPng.dylib (1850.2.14) <A7920CA1-CD86-39B3-85EB-9808AF1DC731> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff327b0000 -     0x7fff327b2ffb  libRadiance.dylib (1850.2.14) <EDBC5EA7-76E1-354C-A631-819889C0BDC4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff327b3000 -     0x7fff32800ff3  libTIFF.dylib (1850.2.14) <4443BFAC-4DBF-3EE0-91BE-F714BA304DC3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff33973000 -     0x7fff3398cfff  com.apple.Kerberos (3.0 - 1) <DB1E0679-37E1-3B93-9789-32F63D660C3B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff343a8000 -     0x7fff34450ff7  com.apple.Metal (162.2 - 162.2) <B65C71BF-D40E-3BB3-940C-117DDD203551> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff3446c000 -     0x7fff3448bff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <44CE8362-E972-3697-AD6F-15BC863BAEB8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff3448c000 -     0x7fff34508fe7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <EE8440DA-66DF-3923-ABBC-E0543211C069> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff34509000 -     0x7fff34530fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <E64450DF-2B96-331E-B7F4-666E00571C70> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff34531000 -     0x7fff3465cff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <F2CF26B6-73F1-3644-8FE9-CDB9B2C4501F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff3465d000 -     0x7fff34677fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B33A35C3-0393-366B-ACFB-F4BB6A5F7B4A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff34678000 -     0x7fff34679ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <69F14BCF-C5C5-3BF8-9C31-8F87D2D6130A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff35476000 -     0x7fff35482ff7  com.apple.NetFS (6.0 - 4.0) <1C8237D6-731D-3E32-8BD5-B92A33D08A30> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff357e5000 -     0x7fff35808ff7  com.apple.audio.OpenAL (1.8 - 1.8) <2EE5236C-775B-36B1-97A8-DEE5FB80F5B5> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff37f17000 -     0x7fff37f1ffe3  libcldcpuengine.dylib (2.11) <AAE49359-EB53-3FD4-ADBF-C60498BD0B34> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff37f20000 -     0x7fff37f77ff7  com.apple.opencl (2.15.3 - 2.15.3) <5D9915B4-59F6-355A-948C-E81CEEEF4933> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff37f78000 -     0x7fff37f93ff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <F03D84EB-49B2-3A00-9127-B9A269824026> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff37f94000 -     0x7fff37f9fffb  com.apple.OpenDirectory (10.14 - 207.200.4) <A8020CEE-5B78-3581-A735-EA2833683F31> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff388ef000 -     0x7fff388f1fff  libCVMSPluginSupport.dylib (17.7.3) <D1E81264-9C8F-38D2-8669-31944FA2FD95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff388f2000 -     0x7fff388f7ff3  libCoreFSCache.dylib (166.7) <B4FA6DF5-D5F7-32B9-8FCD-8FD4E80D31E5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff388f8000 -     0x7fff388fcfff  libCoreVMClient.dylib (166.7) <F24595D0-011C-39C3-A48F-C1ADE643E18A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff388fd000 -     0x7fff38905ff7  libGFXShared.dylib (17.7.3) <9D0250B9-5914-3AA3-BE1E-5431C7646B07> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff38906000 -     0x7fff38911fff  libGL.dylib (17.7.3) <5AB5AF8E-9B3E-39C5-AC86-AB30E057803A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff38912000 -     0x7fff3894cfef  libGLImage.dylib (17.7.3) <68240F7A-470B-3C66-9FEE-95DB2E06EEDB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff3894d000 -     0x7fff38abfff7  libGLProgrammability.dylib (17.7.3) <8284F831-0896-3753-9E13-8074EDC7A633> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff38ac0000 -     0x7fff38afefff  libGLU.dylib (17.7.3) <A19060B3-970A-3C7D-A6CB-34E889CA629F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff3949b000 -     0x7fff394aaffb  com.apple.opengl (17.7.3 - 17.7.3) <7AC113CD-89D7-3123-9E44-898F5B238BEC> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff394ab000 -     0x7fff39642ff7  GLEngine (17.7.3) <7C487F4A-ED08-3E77-9CE7-DCF90C8A99EA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff39643000 -     0x7fff3966cff3  GLRendererFloat (17.7.3) <317D8AC4-97FA-3A28-9136-A7934B1801AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff3a2b4000 -     0x7fff3a50bff7  com.apple.QuartzCore (1.11 - 701.14) <799289BE-DE8E-390A-9DEC-82DDCF5BA319> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3ad43000 -     0x7fff3b044ff7  com.apple.security (7.0 - 58286.270.14) <BDD08930-4D92-3D2A-8FED-F7F74A086BED> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3b045000 -     0x7fff3b0d1fff  com.apple.securityfoundation (6.0 - 55185.260.1) <5CBF715E-7C88-3B8C-8C2F-10B59FA80842> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3b103000 -     0x7fff3b107fff  com.apple.xpc.ServiceManagement (1.0 - 1) <AE9930FD-1AC9-391A-B769-03F6A0F05063> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3b4a0000 -     0x7fff3b50dfff  com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3e749000 -     0x7fff3e7eefef  com.apple.APFS (1.0 - 1) <121C4AD9-617C-3865-8DF5-988E7C686611> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff3f203000 -     0x7fff3f204ff7  com.apple.AggregateDictionary (1.0 - 1) <A6AF8AC4-1F25-37C4-9157-A02E9C200926> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff3f805000 -     0x7fff3f831ff7  com.apple.framework.Apple80211 (13.0 - 1380.2) <E4D12303-8B12-303C-91E2-3B40F60832BA> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff3f959000 -     0x7fff3f968fc7  com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff3fa64000 -     0x7fff3fa6ffff  com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff3fab0000 -     0x7fff3faf9ff3  com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff3fd4d000 -     0x7fff3fd6ffff  com.apple.applesauce (1.0 - ???) <F49107C7-3C51-3024-8EF1-C57643BE4F3B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff3fece000 -     0x7fff3fee2ffb  com.apple.AssertionServices (1.0 - 1) <456E507A-4561-3628-9FBE-173ACE7429D8> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff402b2000 -     0x7fff4039eff7  com.apple.AuthKit (1.0 - 1) <2765ABE9-54F2-3E45-8A93-1261E251B90D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff40560000 -     0x7fff40568fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff40569000 -     0x7fff405fefff  com.apple.backup.framework (1.10.7 - ???) <5243C2BC-0159-3DBB-9FAB-22EA01E58052> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff405ff000 -     0x7fff4066cff3  com.apple.BaseBoard (360.28 - 360.28) <68FA8044-F3CD-3BC6-9DAB-27DACF52BFC0> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff422d9000 -     0x7fff422e2ffb  com.apple.CommonAuth (4.0 - 2.0) <B07CB4D3-12A9-31E0-B393-67BCBD5F8ADB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff42fbb000 -     0x7fff42fccff7  com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff43576000 -     0x7fff435dcff7  com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff43889000 -     0x7fff43891ff7  com.apple.CorePhoneNumbers (1.0 - 1) <11F97C7E-C183-305F-8E6C-9B374F50E26B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff43a0d000 -     0x7fff43a3eff3  com.apple.CoreServicesInternal (358 - 358) <DD6EF60D-048F-3186-83DA-EB191EDF48AE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff43e05000 -     0x7fff43e89fff  com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff43f19000 -     0x7fff44044ff7  com.apple.coreui (2.1 - 499.10) <A80F4B09-F940-346F-A9DF-4EFADD9220A8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff44045000 -     0x7fff441e5fff  com.apple.CoreUtils (5.9 - 590.16) <BF9A990D-24C0-3633-A753-F19F4DFCA663> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff44239000 -     0x7fff4429cff7  com.apple.framework.CoreWiFi (13.0 - 1375.2) <7E9CC352-BB06-3C97-A51F-6A35F09EBA16> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff4429d000 -     0x7fff442aeff3  com.apple.CrashReporterSupport (10.13 - 938.29) <5942C233-DB5E-3119-8DA3-201A5C080191> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff4433e000 -     0x7fff4434dfff  com.apple.framework.DFRFoundation (1.0 - 211.1) <E3F02F2A-2059-39CC-85DA-969676EB88EB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4434e000 -     0x7fff44352ff7  com.apple.DSExternalDisplay (3.1 - 380) <787B9748-B120-3453-B8FE-61D9E363A9E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff443d3000 -     0x7fff44448ffb  com.apple.datadetectorscore (7.0 - 590.27) <06FB1A07-7AE6-3ADD-8E7E-41955FAB38E8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff44494000 -     0x7fff444d1ff7  com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff444d2000 -     0x7fff4460dff7  com.apple.desktopservices (1.13.6 - ???) <7536F3F3-90F1-3D1C-9249-91B809FE5328> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff45554000 -     0x7fff4596ffff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <A576E2DA-BF6F-3B18-8FEB-324E5C5FA9BD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff49223000 -     0x7fff49224fff  libmetal_timestamp.dylib (902.3.2) <05389463-AF2E-33E2-A14F-1416E4A30835> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff4a8b8000 -     0x7fff4a8c3ff7  libGPUSupportMercury.dylib (17.7.3) <C571832A-B074-335D-A12E-5B7A8D42B905> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff4a8c4000 -     0x7fff4a8c9fff  com.apple.GPUWrangler (3.50.16 - 3.50.16) <1156CF8C-729B-3173-B3CC-00BB17156BCC> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff4b6d5000 -     0x7fff4b6e4fff  com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff4b84a000 -     0x7fff4b8beff3  com.apple.Heimdal (4.0 - 2.0) <EDF4255F-704F-32BA-A6EF-F3477A4B1D5B> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff4cbc9000 -     0x7fff4cbd0ffb  com.apple.IOAccelerator (404.15 - 404.15) <15B11DC6-DF66-3E0F-BAB2-573727CEA327> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff4cbd4000 -     0x7fff4cbecfff  com.apple.IOPresentment (1.0 - 42.6) <B5E36058-DB24-3CED-A8FF-980FDCCD6575> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff4cf94000 -     0x7fff4cfc1ff7  com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff4d254000 -     0x7fff4d266ff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <40D1221D-1DFE-3CF3-8DC1-07313F10DA17> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff4d281000 -     0x7fff4d35cff7  com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff4d35d000 -     0x7fff4d399ff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff4d3a0000 -     0x7fff4d3a5fff  com.apple.LinguisticData (1.0 - 238.25) <F529B961-098C-3E4C-A3E9-9DA9BFA1B3F0> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff4e09b000 -     0x7fff4e0c3ff7  com.apple.spotlight.metadata.utilities (1.0 - 1191.58) <23E8580B-19C0-3E4F-A9FE-368DA80EAA6F> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff4e0c4000 -     0x7fff4e151ff7  com.apple.gpusw.MetalTools (1.0 - 1) <9B542958-6363-3041-A265-EC7AC7BD7A43> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff4e2fc000 -     0x7fff4e317ffb  com.apple.MobileKeyBag (2.0 - 1.0) <39337CBB-1D39-3DDC-A998-591194C76523> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff4e3a0000 -     0x7fff4e3caffb  com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <42A23EC9-64A7-31C7-BF33-DF4412ED8A3F> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff4e606000 -     0x7fff4e610fff  com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff4ee72000 -     0x7fff4eec3ff3  com.apple.OTSVG (1.0 - ???) <E43F65D0-080B-3D5C-ADB3-14200AB5CAE4> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5005d000 -     0x7fff5006cff7  com.apple.PerformanceAnalysis (1.218.3.1 - 218.3.1) <B6FF319A-FC61-3EA9-A72D-68E1430429A7> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff51efe000 -     0x7fff51f1cff7  com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D050-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff520b4000 -     0x7fff52104fff  com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff52262000 -     0x7fff52284fff  com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff53a8e000 -     0x7fff53bacfff  com.apple.Sharing (1288.62.5 - 1288.62.5) <BB647030-839A-3271-B205-D4325346DD3B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff549c1000 -     0x7fff54c70ff3  com.apple.SkyLight (1.600.0 - 340.56) <C62B4595-5FE6-3C62-9B90-A86143CD623B> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff55414000 -     0x7fff55420fff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff55b71000 -     0x7fff55bfcfc7  com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff560e2000 -     0x7fff560eeffb  com.apple.TCC (1.0 - 1) <E3691073-7284-35E4-94F3-16587A7F380F> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff56354000 -     0x7fff5641cff3  com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff564d2000 -     0x7fff564d3fff  com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <15DF9C73-54E4-3C41-BCF4-378338C55FB4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff564d9000 -     0x7fff56691ffb  com.apple.UIFoundation (1.0 - 551.5) <A0FDC3A4-45C6-3C87-B77F-7DC394374C08> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff5730d000 -     0x7fff573e6fff  com.apple.ViewBridge (407 - 407) <41AB432A-08A7-3808-8079-B07D742D3F33> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff57bbe000 -     0x7fff57bc1fff  com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff57fc2000 -     0x7fff57fc4ffb  com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff5828e000 -     0x7fff582c2fff  libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
0x7fff582c5000 -     0x7fff582cfff7  libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
0x7fff5835d000 -     0x7fff5835effb  libDiagnosticMessagesClient.dylib (107) <A14D0819-0970-34CD-8680-80E4D7FE8C2C> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff58395000 -     0x7fff585ecff3  libFosl_dynamic.dylib (18.3.4) <1B5DD4E2-8AE0-315E-829E-D5BFCD264EA8> /usr/lib/libFosl_dynamic.dylib
0x7fff5863d000 -     0x7fff5865cfff  libMobileGestalt.dylib (645.270.1) <99A06C8A-97D6-383D-862C-F453BABB48A4> /usr/lib/libMobileGestalt.dylib
0x7fff5865d000 -     0x7fff5865dfff  libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
0x7fff5879d000 -     0x7fff5879effb  libSystem.B.dylib (1252.250.1) <99D9FDA4-DC94-32F4-BAD9-3726618F00FC> /usr/lib/libSystem.B.dylib
0x7fff5881a000 -     0x7fff5881bfff  libThaiTokenizer.dylib (2.15.1) <ADB37DC3-7D9B-3E73-A72A-BCC3433C937A> /usr/lib/libThaiTokenizer.dylib
0x7fff5882d000 -     0x7fff58843ffb  libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
0x7fff58844000 -     0x7fff5886dffb  libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
0x7fff5886e000 -     0x7fff588edfff  libate.dylib (1.13.8) <92B44EDB-369D-3EE8-AEC5-61F8B9313DBF> /usr/lib/libate.dylib
0x7fff588f1000 -     0x7fff588f1ff3  libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
0x7fff589c3000 -     0x7fff589d3ffb  libbsm.0.dylib (39.200.18) <CF381E0B-025B-364F-A83D-2527E03F1AA3> /usr/lib/libbsm.0.dylib
0x7fff589d4000 -     0x7fff589e1fff  libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
0x7fff589e2000 -     0x7fff58a35ff7  libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
0x7fff58a36000 -     0x7fff58a4bff7  libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
0x7fff58a4c000 -     0x7fff58a4cff3  libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
0x7fff58a4d000 -     0x7fff58a5dffb  libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
0x7fff58a5e000 -     0x7fff58a76ffb  libcompression.dylib (52.250.2) <7F4BB18C-1FB4-3825-8D8B-6E6B168774C6> /usr/lib/libcompression.dylib
0x7fff58ceb000 -     0x7fff58d01fff  libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
0x7fff58d02000 -     0x7fff58d03ff3  libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff58ea1000 -     0x7fff58f99ff7  libcrypto.35.dylib (22.260.1) <91C3D71A-4D1D-331D-89CC-67863DF10574> /usr/lib/libcrypto.35.dylib
0x7fff591af000 -     0x7fff59205ff3  libcups.2.dylib (462.16) <E82021D0-36AD-3FB7-AE47-A03A6947C7D0> /usr/lib/libcups.2.dylib
0x7fff5933a000 -     0x7fff5933afff  libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
0x7fff5936c000 -     0x7fff59371ff7  libgermantok.dylib (17.15.2) <E5F0F794-FF27-3D64-AE52-C78C6A84DD67> /usr/lib/libgermantok.dylib
0x7fff59372000 -     0x7fff59377ff7  libheimdal-asn1.dylib (520.270.7) <F5FFC8CB-8530-3FD0-B8C9-0CA2F8BF1035> /usr/lib/libheimdal-asn1.dylib
0x7fff593a2000 -     0x7fff59492fff  libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
0x7fff59493000 -     0x7fff596f4ffb  libicucore.A.dylib (62141.0.1) <A0D63918-76E9-3C1B-B255-46F4C1DA7FE8> /usr/lib/libicucore.A.dylib
0x7fff59741000 -     0x7fff59742fff  liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
0x7fff59743000 -     0x7fff5975bff3  liblzma.5.dylib (10.200.3) <E1F4FD60-1CE4-37B9-AD95-29D348AF1AC0> /usr/lib/liblzma.5.dylib
0x7fff59773000 -     0x7fff59817ff7  libmecab.1.0.0.dylib (779.24.1) <A8D0379B-85FA-3B3D-89ED-5CF2C3826AB2> /usr/lib/libmecab.1.0.0.dylib
0x7fff59818000 -     0x7fff59a1cfff  libmecabra.dylib (779.24.1) <D71F71E0-30E2-3DB3-B636-7DE13D51FB4B> /usr/lib/libmecabra.dylib
0x7fff59bf4000 -     0x7fff59f45ff7  libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
0x7fff59fd7000 -     0x7fff5a75cfdf  libobjc.A.dylib (756.2) <7C312627-43CB-3234-9324-4DEA92D59F50> /usr/lib/libobjc.A.dylib
0x7fff5a76e000 -     0x7fff5a772ffb  libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
0x7fff5a775000 -     0x7fff5a7aafff  libpcap.A.dylib (79.250.4) <17AD7BD4-CF1C-32A0-A4FB-F1B460D652B9> /usr/lib/libpcap.A.dylib
0x7fff5a8c3000 -     0x7fff5a8dbffb  libresolv.9.dylib (65.200.3) <1FB0982D-84D9-36E0-B3D8-C808891EFF50> /usr/lib/libresolv.9.dylib
0x7fff5a92e000 -     0x7fff5ab0bfff  libsqlite3.dylib (274.26) <6404BA3B-BCA4-301F-B2FE-8776105A2AA3> /usr/lib/libsqlite3.dylib
0x7fff5abff000 -     0x7fff5ac4aff7  libstdc++.6.dylib (104.1) <BF6E1E5B-5DF2-3069-A926-20ABF03832B3> /usr/lib/libstdc++.6.dylib
0x7fff5ad24000 -     0x7fff5ad27ff7  libutil.dylib (51.200.4) <CE9B18C9-66ED-32D4-9D29-01F8FCB467B0> /usr/lib/libutil.dylib
0x7fff5ad28000 -     0x7fff5ad35fff  libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
0x7fff5ad3a000 -     0x7fff5ae1dfff  libxml2.2.dylib (32.19) <0A511058-87D0-3CBE-9298-5CBBDAE9A125> /usr/lib/libxml2.2.dylib
0x7fff5ae1e000 -     0x7fff5ae46ff3  libxslt.1.dylib (16.7.2) <1D461E00-A0A1-374C-9EED-3230BFA30042> /usr/lib/libxslt.1.dylib
0x7fff5ae47000 -     0x7fff5ae59ff7  libz.1.dylib (70.200.4) <B048FC1F-058F-3A08-A1FE-81D5308CB3E6> /usr/lib/libz.1.dylib
0x7fff5b63d000 -     0x7fff5b641ff3  libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
0x7fff5b642000 -     0x7fff5b64cff3  libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
0x7fff5b64d000 -     0x7fff5b654ff7  libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
0x7fff5b655000 -     0x7fff5b65eff7  libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
0x7fff5b65f000 -     0x7fff5b6e4fff  libcorecrypto.dylib (602.260.3) <9D9C206B-AB19-3257-95D7-59A993845640> /usr/lib/system/libcorecrypto.dylib
0x7fff5b76b000 -     0x7fff5b7a4ff7  libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib
0x7fff5b7a5000 -     0x7fff5b7d1ff7  libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
0x7fff5b7d2000 -     0x7fff5b7d2ffb  libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
0x7fff5b7d3000 -     0x7fff5b7dfff3  libkxld.dylib (4903.278.68) <67395DF6-BAB8-3A46-8A31-AA8D1FC2806C> /usr/lib/system/libkxld.dylib
0x7fff5b7e0000 -     0x7fff5b7e0ff7  liblaunch.dylib (1336.261.7) <688DAED5-8930-3271-BAEF-68AA48DF5EBB> /usr/lib/system/liblaunch.dylib
0x7fff5b7e1000 -     0x7fff5b7e6fff  libmacho.dylib (927.0.3) <A377D608-77AB-3F6E-90F0-B4F251A5C12F> /usr/lib/system/libmacho.dylib
0x7fff5b7e7000 -     0x7fff5b7e9ff7  libquarantine.dylib (86.270.1) <3F36A3D6-9606-3D90-B520-809BAEF981C3> /usr/lib/system/libquarantine.dylib
0x7fff5b7ea000 -     0x7fff5b7ebff7  libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
0x7fff5b7ec000 -     0x7fff5b803ff3  libsystem_asl.dylib (356.200.4) <A62A7249-38B8-33FA-9875-F1852590796C> /usr/lib/system/libsystem_asl.dylib
0x7fff5b804000 -     0x7fff5b804ff7  libsystem_blocks.dylib (73) <A453E8EE-860D-3CED-B5DC-BE54E9DB4348> /usr/lib/system/libsystem_blocks.dylib
0x7fff5b805000 -     0x7fff5b88cfff  libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
0x7fff5b88d000 -     0x7fff5b890ffb  libsystem_configuration.dylib (963.270.3) <2B4A836D-68A4-33E6-8D48-CD4486B03387> /usr/lib/system/libsystem_configuration.dylib
0x7fff5b891000 -     0x7fff5b894ff7  libsystem_coreservices.dylib (66.1) <44E0194F-06DA-3902-9A45-556606F85168> /usr/lib/system/libsystem_coreservices.dylib
0x7fff5b895000 -     0x7fff5b89bfff  libsystem_darwin.dylib (1272.250.1) <EC9B39A5-9592-3577-8997-7DC721D20D8C> /usr/lib/system/libsystem_darwin.dylib
0x7fff5b89c000 -     0x7fff5b8a2ffb  libsystem_dnssd.dylib (878.270.3) <D5352ABD-0311-3327-8E64-93F29EB19BF1> /usr/lib/system/libsystem_dnssd.dylib
0x7fff5b8a3000 -     0x7fff5b8eeffb  libsystem_info.dylib (517.200.9) <D09D5AE0-2FDC-3A6D-93EC-729F931B1457> /usr/lib/system/libsystem_info.dylib
0x7fff5b8ef000 -     0x7fff5b917ff7  libsystem_kernel.dylib (4903.278.68) <CC310B22-03FD-3068-89D5-46E87FC92EA4> /usr/lib/system/libsystem_kernel.dylib
0x7fff5b918000 -     0x7fff5b963ff7  libsystem_m.dylib (3158.200.7) <F19B6DB7-014F-3820-831F-389CCDA06EF6> /usr/lib/system/libsystem_m.dylib
0x7fff5b964000 -     0x7fff5b98efff  libsystem_malloc.dylib (166.270.1) <011F3AD0-8E6A-3A89-AE64-6E5F6840F30A> /usr/lib/system/libsystem_malloc.dylib
0x7fff5b98f000 -     0x7fff5b999ff7  libsystem_networkextension.dylib (767.250.2) <FF06F13A-AEFE-3A27-A073-910EF78AEA36> /usr/lib/system/libsystem_networkextension.dylib
0x7fff5b99a000 -     0x7fff5b9a1fff  libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
0x7fff5b9a2000 -     0x7fff5b9abfef  libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib
0x7fff5b9ac000 -     0x7fff5b9b6ff7  libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
0x7fff5b9b7000 -     0x7fff5b9baff7  libsystem_sandbox.dylib (851.270.5) <20D11F30-783F-3A56-9BD2-6CF38C049332> /usr/lib/system/libsystem_sandbox.dylib
0x7fff5b9bb000 -     0x7fff5b9bdff3  libsystem_secinit.dylib (30.260.2) <EF1EA47B-7B22-35E8-BD9B-F7003DCB96AE> /usr/lib/system/libsystem_secinit.dylib
0x7fff5b9be000 -     0x7fff5b9c5ff3  libsystem_symptoms.dylib (820.267.2) <0DA60956-0403-3456-9D6A-11F2DB9E3819> /usr/lib/system/libsystem_symptoms.dylib
0x7fff5b9c6000 -     0x7fff5b9dbff7  libsystem_trace.dylib (906.260.3) <5B6FAE61-EF5C-381F-B71B-9B6F6428FEE2> /usr/lib/system/libsystem_trace.dylib
0x7fff5b9dd000 -     0x7fff5b9e2ffb  libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
0x7fff5b9e3000 -     0x7fff5ba12fff  libxpc.dylib (1336.261.7) <404F0E1A-30BC-3CFB-98D3-4A2167CC2AB8> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 49028
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=625.2M resident=0K(0%) swapped_out_or_unallocated=625.2M(100%)
Writable regions: Total=877.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=877.8M(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
CG backing stores 992K 2
CG image 36K 4
CoreAnimation 84K 8
CoreGraphics 8K 1
CoreImage 28K 3
CoreUI image data 420K 6
CoreUI image file 516K 6
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 369.6M 163
MALLOC guard page 32K 6
MALLOC_LARGE (reserved) 772K 2 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
Memory Tag 249 156K 2
OpenGL GLSL 256K 3
STACK GUARD 100K 25
Stack 84.2M 25
VM_ALLOCATE 36.6M 56
VM_ALLOCATE (reserved) 36K 1 reserved VM address space (unallocated)
DATA 77.2M 254
FONT_DATA 4K 1
GLSLBUILTINS 5176K 1
LINKEDIT 276.3M 19
TEXT 349.0M 258
UNICODE 564K 1
mapped file 76.7M 24
shared memory 4560K 9
TOTAL 1.6G 886
TOTAL, minus reserved VM space 1.3G 886
Model: MacBookPro11,4, BootROM 199.0.0.0.0, 4 processors, Intel Core i7, 2,2 GHz, 16 GB, SMC 2.29f24
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533642465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533642465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x152), Broadcom BCM43xx 1.0 (7.77.61.3 AirPortDriverBrcmNIC-1305.12)
Bluetooth: Version 6.0.14d12, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Bluetooth USB Host Controller
USB Device: USB-PS/2 Optical Mouse
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
In such case issue is likely within your file. Can you simplify it as much as possible (but make sure it still crashes) and upload it here?
There you have it - cheers
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Triage.Sep 3 2021, 12:57 PM
I wasn't able to reproduce the issue with provided file. Perhaps this is also mac specific.
@Ankit Meel (ankitm) Can you reproduce?
Empty ~/Library/Application Support/Blender, version 2.93.0, opened the file, Edit > menu search, no crash
macOS 10.14
Well, this is only an issue 2.93.0 alpha. I have also 3.0.0. alpha and 2.9 and everything is fine there.
Not an issue on 2.93.5 candidate blender-2.93.5-candidate+v293.ae1a57a05eed-darwin.x86_64-release.dmg either.
Suggest running mv ~/Library/Application\ Support/Blender ~/Desktop in Terminal and then reopening Blender.
Why are you using 2.93.0 alpha, and not newer LTS releases ?
I was using it just becuse of a certain addon. I use 3.0.0. almost exclusively now.
Ankit Meel (ankitm) closed this task as Resolved.Sep 3 2021, 3:05 PM
Ankit Meel (ankitm) claimed this task.
Assuming fixed then
