the resolution of metaball has be limited
Needs Information from Developers, NormalPublic
Operating system: Linux-5.13.13-hardened1-1-hardened-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce GTX 1060 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-04 16:28, hash: rB079bd1155636
Worked:
I think it needs to fix because small metaballs can't show correctly. T75999
I created a metaball with 5 mm radius.
but these values is lower than minimum limit (5 mm).
I can't change it to a smaller value because of limits.
  1. Add a metaball of 5 mm radius (resolution will be of 1mm)
  2. Try changing the resolution to a smaller value.
  3. Meta ball will no longer be visible (as resolution will reset to it's minimum value: 5mm)
Hi, thanks for the report. This is an intentional behavior as @Germano Cavalcante (mano-wii) said in T75999: Can't change Metaball Resolution lower than 5mm
But as described in this report, it fails for the object with smaller radius (meta ball disappears on changing the resolution).
Will keep the report open for developers to answer.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Sep 6 2021, 9:16 AM
