Graphics card: NVIDIA GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-15 23:08, hash: rB899935d5d024
Worked: None
Normally, if you run this operation 'bpy.ops.object.convert(target='MESH')' on the active mesh object then all the modifiers get applied at once. However, if the last modifier is a geometry nodes modifier and the last node before the group output in the modifiers node group is 'point instance' then running the above operation produces an empty mesh with no vertices
- open the attached blend file
- Go to Object->Convert->Mesh
- Does not work as expected (the object mesh becomes empty)
- repeat everything but this time add any new modifier or add any node in geometry nodes after 'point instance' node
- Everything seems to work fine
