Proportional Size Ring off screen
Operating system: macOS-11.5.2-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 48 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.6.20
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-10 21:22, hash: rBeab26f13347d
Using an exact scale for product, the default object size is greatly reduced from the default range. Upon first usage of Proportional node dragging the Size ring is off the screen and not showing. In the Move dialogue the Proportional Size was 100 x the Edited Object's size. Additionally, the Dialogue just says "Proportional Is" and this dialogue comes up AFTER the first attempt to use it.
The logical thing is to have the Proportional Size programmed to be no larger than half the size of the Edited Object so that it could at least be found and usable. If this is not possible, then at least have the Dialogue Box with Proportional Size available upon selection of Proportional edit selection.
I believe this is explicit enough not to require uploading the sample BLEND file, but am happy to do so. In the screenshot I changed the ProProportional Size ring just enough so it shows on the ritght edge of the working area to give you the nature of the problem. Actually it was not even showing in the greatly zoomed out scene with the default camera and light which I had not changed from initially opening the project.
Related Objects
Hi and thx for the report!
Proportional starts at 1 [which suits the size of default objects in blender]
Not sure it is this simple (there might be usecases where you actually want the size to be much greater -- even greater than what can be shown on screen with the circle).
Keep in mind this can also be used in objectmode to transform many selected objects in relation to each other.
We could do something (roughly) like
1
2
3diff --git a/release/scripts/startup/bl_ui/space_view3d.py b/release/scripts/startup/bl_ui/space_view3d.py
4index c6bc6d9b5d3..f98647f0f6c 100644
5--- a/release/scripts/startup/bl_ui/space_view3d.py
6+++ b/release/scripts/startup/bl_ui/space_view3d.py
7@@ -6651,7 +6651,7 @@ class VIEW3D_PT_proportional_edit(Panel):
8 col = layout.column()
9 col.active = (tool_settings.use_proportional_edit_objects if context.mode == 'OBJECT'
10 else tool_settings.use_proportional_edit)
11-
12+ col.prop(tool_settings, "proportional_size")
13 if context.mode != 'OBJECT':
14 col.prop(tool_settings, "use_proportional_connected")
15 sub = col.column()
@Germano Cavalcante (mano-wii): is there a reason we expose this nowhere in the UI?
But strictly speaking, the issue reported here is a request for modified/improved behavior and not a bug in current behavior.
Will have to close as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
@Germano Cavalcante (mano-wii): is there a reason we expose this nowhere in the UI?(...)
I don't know any reasons for this (maybe to avoid populating the UI with too much information?).
It would make sense to me to expose this property in the Proportional Editing's Popover.
It would also be good to expose in other editors.
