Hair Particle Error
When I put the hair particles in place, they are not put, but in modification properties I get to allow the mesh to form. But then it does not let me modify it since it disappears and the changes do not come out to modify it.
Robert Guetzkow (rjg) closed this task as Archived.Sep 19 2021, 2:39 PM
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read this guide, it may help you write a bug report that allows us to identify the cause of the problem.
If you need help using Blender, please post a question on one of our community websites, for instance Blender's StackExchange, blenderartists.org or the #support channel on Blender chat. The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template. Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
