Graphics card: NVIDIA GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.96
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-18 19:45, hash: rBbdbc7e12a02e
No sure whether it is on the Cycles side or Geometry Nodes side. The instances are not visible in the final render, in the viewport you can get it to work by chance if you keep turning the Geometry Nodes modifier on and off. I just happened to get the bug and saved this file, I don't know how to reproduce it from startup.
Based on an attached .blend file
- Open the attached file and hit rendered view
- Confirm it is invisible, then try to turn the modifier on and off, see it shows up occasionally
- Hit final render, see it does not show in the final image
