Click and drag on the right panel tabs will call active tool (Tweak, Box Select etc)
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.41
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-20 20:10, hash: rB13a4bccdb196
As titile said
Select object, Click and drag on the tab of right panel.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.EditedSep 22 2021, 7:40 AM
Hi @Vyacheslav (hitrpr) , thanks for the report. I am not able to reproduce it on master: 4d881d9dad764dec22c057f434d3f91c26f0b0ef
Did you check the case with default settings?
I can only reproduce if Sculpt mode is active (which @TheRedWaxPolice (TheRedWaxPolice) has mentioned)
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.Sep 22 2021, 9:40 AM
I can confirm. It is calling the active tool [e.g. could be box select as well]
I think this has been reported before, let me see if I can find it.
@Campbell Barton (campbellbarton) might know right away
Philipp Oeser (lichtwerk) renamed this task from Click and drag on the right panel tabs will call Grab if object selected to Click and drag on the right panel tabs will call active tool (Tweak, Box Select etc).Sep 22 2021, 9:42 AM
Yes, the same with factory settings.
Box select called instead drag (idk why it is still default)
Julian Eisel (Severin) closed this task as Resolved.Jan 27 2022, 6:47 PM
Julian Eisel (Severin) claimed this task.
