Handling of missing plugins
Operating system: Windows 10, 64bit
Graphics card: GeForce GTX 1080ti
Broken: 2.93.2, others as well
Blender crashes on startup, when enabled plugin is removed. I found this out with the Redshift plugin specifically. After updating Redshift to a newer version and removing the old one, I was unable to start blender without an immediate crash, even before the splash screen. I had to reset Blender to factory defaults, losing all of my customizations.
A more graceful handling of a missing plugin would be great... an error message for example, or at least a way to access and edit your user settings, so you don't lose your entire config after updating one plugin.
Opening Blender and disabling the plugin before updating and re-installing the plugin afterwards works, but with Redshift releasing new versions almost weekly, I'm bound to forget to do this before an update again.
-install an older version of Redshift (3.50 in my case)
-enable Redshift plugin in Blender, close Blender (which should save new config)
-update Redshift to a newer version (3.56 in my case, 3.54 before I found out what was causing the crashes) and make sure older Redshift version is removed
-start Blender, it should now crash even before showing the splash screen
Richard Antalik (ISS) closed this task as Archived.Sep 22 2021, 8:36 PM
From crash log this looks like crash happened within addon, not Blender. Though I was not able to reproduce crash in 3.0, but not sure if this is due to some internal workings in addon.
Please report this issue with addon developers.
