Blender Cycles-X SSS/Transparent problem
Closed, ResolvedPublicBUG
Operating system: Windows 10 May 2021 Update
Graphics card: tested in rtx 3060 ti and gtx 1060
Broken: Blender 3.0 Cycles-X branch 22/09/2021 (and older Cycles-X versions)
Worked: Not Cycles-X versions
I think there is a problem with transparent objects and SSS (both “fixed radius” and normal random walk), when you use a transparent object on top of an object with SSS there is a strange effect in which you can still see the shape of the object.
Video example:
https://youtu.be/RYQzz4JwgQ4
  1. add Principled BSDF to an object
  2. add the color/texture to base color and subsurface color
  3. raise the value of subsurface to any value above 0 (with fixed radius or normal random walk)
  4. add another object only with a transparent shader on top of the object.
Example .blend
Alaska (Alaska) changed the task status from Needs Triage to Confirmed.Sep 23 2021, 9:43 AM
Alaska (Alaska) changed the subtype of this task from "Report" to "Bug".
Alaska (Alaska) added a subscriber: Alaska (Alaska).
I can confirm the bug with the provided file. It is rather subtle.
Operating system: Linux-5.10.0-8-amd64-x86_64-with-glibc2.32 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-23 05:54, hash: rBa351023bd50c
