Regression: attached Vector Rotate nodes detach
Closed, ResolvedPublicBUG
Linux Mint 20.2 Cinnamon
3400G
Broken:
blender-3.0.0-alpha+master.26141664f0c4-linux.x86_64-release.tar.xz
Worked:
blender-2.93.4-linux-x64 (official release)
blender-3.0.0-alpha+cycles-x.342cdb03ee06-linux.x86_64-release.tar.xz
Previously attached Vector Rotate nodes detach when opened in the latest Blender version.
Compare the following .blend file in 2.93.4 and in the most recent 3.0.0 alpha version.
Possibly connected with this commit? rBc99cb814520480379276192f044c673ef857447b
In case helpful, from tests, all other Vector nodes remain attached, appears only the Vector Rotate node is affected.
Hans Goudey (HooglyBoogly) changed the task status from Needs Triage to Confirmed.Sep 24 2021, 6:54 AM
Hans Goudey (HooglyBoogly) claimed this task.
Hans Goudey (HooglyBoogly) changed the subtype of this task from "Report" to "Bug".
Thanks for the report! Fix incoming
Thank you for your impressively quick fix!
