Ошибка Blenderkit
Graphics card: NVIDIA GeForce GTX 650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: rBb7205031cec4
Addon Information
Name: BlenderKit Online Asset Library (2, 93, 0)
Author: Vilem Duha, Petr Dlouhy
При загрузке материалов или моделей в blenderkit они не загружаются как показано на скриншоте
Нашел проблему, проблему аддона вызывал аддон textools
Google Translate: Found a problem, the textools addon was causing the addon problem
Hi, thanks for the report. Texttools add-on is not maintained by Blender.
Please report this issue to add-on developers: https://github.com/SavMartin/TexTools-Blender/issues
Developers will report the bug on tracker if recent changes in code are stopping their add-on from working :)
Closing the ticket for now but feel free to reopen if the issue is related to Blender-kit add-on.
Also carefully follow the instructions. Provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
(A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports)
