AutoDepth ignores texture transparency
Needs Information from Developers, NormalPublic
Operating system: Win 10 64-bit
Graphics card: 980 Ti
Broken: 2.93.4 LTS, 3.0 alpha (including current latest build)
Worked: 2.79
When navigating using mouse with auto-depth enabled, the full-transparent parts of textures should be ignored when picking the depth.
This worked correctly in 2.79, but 2.93 and the latest 3.0 alpha seem to ignore this.
Enable Auto-Depth, create an object, assign it a material with some full-transparent texture, then try to zoom / pan using mouse with the cursor on it.
That report is not related - it is describing the auto-depth behavior with semi-transparent images, but what I have reported is that fully transparent area of an image should be ignored when getting the depth.
You can test it on this scene - try to zoom through the hole
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from Developers.Oct 4 2021, 6:26 PM
While in Workbench objects with transparency don't write depth, in Eevee this apparently doesn't happen.
I don't know if it's a bug or something that wasn't implemented due to the complexity of Eevee compared to Workbench.
This seems like something for the EEVEE & Viewport team to decide.
This remains the issue even in 3.3 / 3.4. Any chance for a fix? Thanks
