2.9.3 Crash leaving Weight Paint mode with gscatter add-on
Operating system: MacOS 10.14.6
Graphics card: Radeon Pro 575X 4 GB
Broken: 2.93.4 release
Add-on version: Graswald gscatter 0.3.4
Blender Crashes when leaving Weight Paint mode while using gscatter add-on
100% reproducible on my system.
Install gscatter add-on
Launch Blender 2.9.3.
Open gScatter tab in Option panel.
Use the "Surface" eyedropper to select Default Cube as target object.
Click "My Assets", select any asset (preinstalled with add-on) in the selection window, click "Scatter Selected", click OK
Click the "Vertex Mask" Paintbrush. Mode changes to "Weight Paint" mode.
PROBLEM: Whether you paint anything or not, leaving "Weight Paint" mode by ANY method (selecting another mode from the Mode popup, or clicking the "Vertex Mask" paintbrush again, or selecting a differing environment from the top menu bar) immediately crashes Blender.
WORKAROUND: if you SAVE the file after doing the Weight Painting, then immediately quit Blender, then relaunch Blender and open the saved file, it will open up in Weight Paint mode, but then will NOT crash on switching out.
Crash report:
Process: Blender [82069]
Path: /Applications/Blender 2.93.4.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 2.93.4 (2.93.4 2021-09-01)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Blender [82069]
User ID: 502
Date/Time: 2021-10-06 11:49:02.383 -0700
OS Version: Mac OS X 10.14.6 (18G95)
Report Version: 12
Anonymous UUID: BC89DB4F-3B1C-4ED1-7B7E-D5AAE81B897E
Time Awake Since Boot: 180000 seconds
System Integrity Protection: disabled
Crashed Thread: 1
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: Blender [82069]
Thread 0:: Dispatch queue: com.apple.main-thread
0 org.blenderfoundation.blender 0x0000000108aa1bf8 WM_msgbus_handle + 72
1 org.blenderfoundation.blender 0x0000000108a6c92a wm_event_do_notifiers + 1770
2 org.blenderfoundation.blender 0x0000000108a672c8 WM_main + 40
3 org.blenderfoundation.blender 0x000000010855525b main + 907
4 libdyld.dylib 0x00007fff698203d5 start + 1
Thread 1 Crashed:
0 libsystem_kernel.dylib 0x00007fff69955266 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fff697d3bd9 _dispatch_sema4_wait + 16
2 libdispatch.dylib 0x00007fff697d439f _dispatch_semaphore_wait_slow + 98
3 org.blenderfoundation.blender 0x000000010f7abcaf IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 79
4 org.blenderfoundation.blender 0x000000010f7aa73e void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 62
5 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
6 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
7 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
0 libsystem_pthread.dylib 0x00007fff69a133f0 start_wqthread + 0
Thread 8:
Thread 9:
Thread 10:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff6995522a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff6995576c mach_msg + 60
2 com.apple.audio.CoreAudio 0x00007fff3d2ceeda HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 122
3 com.apple.audio.CoreAudio 0x00007fff3d2cee4f HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 45
4 com.apple.audio.CoreAudio 0x00007fff3d2cb39f HALC_ProxyIOContext::IOWorkLoop() + 1017
5 com.apple.audio.CoreAudio 0x00007fff3d2cadf4 HALC_ProxyIOContext::IOThreadEntry(void*) + 122
6 com.apple.audio.CoreAudio 0x00007fff3d2ca956 HALB_IOThread::Entry(void*) + 72
7 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
8 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
9 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 11:
1 org.blenderfoundation.blender 0x0000000108a5e068 tbb::internal::rml::private_worker::run() + 344
2 org.blenderfoundation.blender 0x0000000108a5df09 tbb::internal::rml::private_worker::thread_routine(void*) + 9
3 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
4 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
5 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
0 libsystem_kernel.dylib 0x00007fff6995886a __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff69a1756e _pthread_cond_wait + 722
2 org.blenderfoundation.blender 0x000000010ff07d39 PyThread_acquire_lock_timed + 553
3 _queue.cpython-39-darwin.so 0x000000012dd10561 _queue_SimpleQueue_get_impl + 385
4 _queue.cpython-39-darwin.so 0x000000012dd1015f _queue_SimpleQueue_get + 191
5 org.blenderfoundation.blender 0x000000010fe05fc4 cfunction_vectorcall_FASTCALL_KEYWORDS + 132
6 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
7 org.blenderfoundation.blender 0x000000010feaeda6 _PyEval_EvalFrameDefault + 26614
8 org.blenderfoundation.blender 0x000000010feb2fd2 _PyEval_EvalCode + 3282
9 org.blenderfoundation.blender 0x000000010fdc2711 _PyFunction_Vectorcall + 257
10 org.blenderfoundation.blender 0x000000010feaeff4 _PyEval_EvalFrameDefault + 27204
11 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
12 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
13 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
14 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
15 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
16 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
17 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
18 org.blenderfoundation.blender 0x000000010fdc4df0 method_vectorcall + 336
19 org.blenderfoundation.blender 0x000000010ff59b86 t_bootstrap + 70
20 org.blenderfoundation.blender 0x000000010ff07919 pythread_wrapper + 25
21 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
22 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
23 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 17:
Thread 18:
0 libsystem_kernel.dylib 0x00007fff6995d36e poll + 10
1 select.cpython-39-darwin.so 0x000000012d891779 select_poll_poll + 313
2 org.blenderfoundation.blender 0x000000010fdcb49c method_vectorcall_FASTCALL + 140
3 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
4 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
5 org.blenderfoundation.blender 0x000000010feb2fd2 _PyEval_EvalCode + 3282
6 org.blenderfoundation.blender 0x000000010fdc2711 _PyFunction_Vectorcall + 257
7 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
8 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
9 org.blenderfoundation.blender 0x000000010feb2fd2 _PyEval_EvalCode + 3282
10 org.blenderfoundation.blender 0x000000010fdc2711 _PyFunction_Vectorcall + 257
11 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
12 org.blenderfoundation.blender 0x000000010feaee42 _PyEval_EvalFrameDefault + 26770
13 org.blenderfoundation.blender 0x000000010feb2fd2 _PyEval_EvalCode + 3282
14 org.blenderfoundation.blender 0x000000010fdc2711 _PyFunction_Vectorcall + 257
16 org.blenderfoundation.blender 0x000000010feaed13 _PyEval_EvalFrameDefault + 26467
18 org.blenderfoundation.blender 0x000000010fdc4e68 method_vectorcall + 456
19 org.blenderfoundation.blender 0x000000010feaeff4 _PyEval_EvalFrameDefault + 27204
20 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
21 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
22 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
23 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
24 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
25 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
26 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
27 org.blenderfoundation.blender 0x000000010fdc4df0 method_vectorcall + 336
28 org.blenderfoundation.blender 0x000000010ff59b86 t_bootstrap + 70
29 org.blenderfoundation.blender 0x000000010ff07919 pythread_wrapper + 25
30 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
31 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
32 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 19:
6 org.blenderfoundation.blender 0x000000010fddff07 calliter_iternext + 71
7 org.blenderfoundation.blender 0x000000010feae60d _PyEval_EvalFrameDefault + 24669
8 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
10 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
12 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
13 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
14 org.blenderfoundation.blender 0x000000010feb1ea7 call_function + 407
15 org.blenderfoundation.blender 0x000000010feaecf3 _PyEval_EvalFrameDefault + 26435
16 org.blenderfoundation.blender 0x000000010fdc2805 function_code_fastcall + 229
17 org.blenderfoundation.blender 0x000000010fdc4df0 method_vectorcall + 336
18 org.blenderfoundation.blender 0x000000010ff59b86 t_bootstrap + 70
19 org.blenderfoundation.blender 0x000000010ff07919 pythread_wrapper + 25
20 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
21 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
22 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 20:
Thread 21:: com.apple.NSEventThread
2 com.apple.CoreFoundation 0x00007fff3d85f1ee CFRunLoopServiceMachPort + 328
3 com.apple.CoreFoundation 0x00007fff3d85e75c
CFRunLoopRun + 1612
4 com.apple.CoreFoundation 0x00007fff3d85debe CFRunLoopRunSpecific + 455
5 com.apple.AppKit 0x00007fff3ae5d4c2 _NSEventThread + 175
6 libsystem_pthread.dylib 0x00007fff69a142eb _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff69a17249 _pthread_start + 66
8 libsystem_pthread.dylib 0x00007fff69a1340d thread_start + 13
Thread 1 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000e  rbx: 0x0000600003a580e0  rcx: 0x0000700005aa2e68  rdx: 0x0000000000000028
rdi: 0x0000000000002903  rsi: 0x0000000000000003  rbp: 0x0000700005aa2e80  rsp: 0x0000700005aa2e68
 r8: 0x0000000000001503   r9: 0x0000000000000000  r10: 0x0000000000002903  r11: 0x0000000000000246
r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x0000600003a580e0  r15: 0xffffffffffffffff
rip: 0x00007fff69955266  rfl: 0x0000000000000246  cr2: 0x0000700005aa2f78
Logical CPU: 0
Error Code: 0x01000024
Trap Number: 133
Binary Images:
   0x1083ee000 -        0x114201fcf +org.blenderfoundation.blender (2.93.4 - 2.93.4 2021-09-01) <AEB36356-2044-3E52-BD88-855DD9086D52> /Applications/Blender 2.93.4.app/Contents/MacOS/Blender
   0x11abd4000 -        0x11ac40ffb +libomp.dylib (0) <535E76BC-1650-3651-9C62-97A995647107> /Applications/Blender 2.93.4.app/Contents/Resources/lib/libomp.dylib
   0x11b042000 -        0x11b046ffb  com.apple.audio.AppleHDAHALPlugIn (282.54 - 282.54) <207D25F0-B094-3569-AA6D-09B4EDD72861> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
   0x11b0ac000 -        0x11b241fff  com.apple.audio.units.Components (1.14 - 1.14) <8B1DABE8-8F96-364D-9C60-36B06CD73466> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
   0x11e1b7000 -        0x11e1b9ff3 +_posixsubprocess.cpython-39-darwin.so (0) <9C57F5CA-A5CA-3639-82C5-5D220243E6FB> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_posixsubprocess.cpython-39-darwin.so
   0x11f220000 -        0x11f223047  libobjc-trampolines.dylib (756.2) <5795A048-3940-3801-90CE-33D1B1AF81F4> /usr/lib/libobjc-trampolines.dylib
   0x11f387000 -        0x11f389fff +_heapq.cpython-39-darwin.so (0) <996F865D-3488-3FAF-B356-F56036C1F827> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
   0x11f391000 -        0x11f392ff7 +grp.cpython-39-darwin.so (0) <F1836FC4-772C-3544-A6CD-5734B5B3116F> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/grp.cpython-39-darwin.so
   0x11f566000 -        0x11f567fff +_dynfunc.cpython-39-darwin.so (0) <76DCF259-7C5F-3A0E-ADB3-23520EE09F3F> /Users/USER/*/_dynfunc.cpython-39-darwin.so
   0x11f56a000 -        0x11f570ff7 +_dispatcher.cpython-39-darwin.so (0) <DB082428-5D46-3555-8F8A-906B58E92AAE> /Users/USER/*/_dispatcher.cpython-39-darwin.so
   0x11f575000 -        0x11f575fff +_devicearray.cpython-39-darwin.so (0) <274387E1-270C-3B22-B39B-ADEF47E892DE> /Users/USER/*/_devicearray.cpython-39-darwin.so
   0x11f578000 -        0x11f578ffb +_scproxy.cpython-39-darwin.so (0) <56335384-04E4-371D-80CA-E6B105D23B71> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_scproxy.cpython-39-darwin.so
   0x11f5ba000 -        0x11f5bbfff +_typeconv.cpython-39-darwin.so (0) <53B96668-FEE1-3348-B5CF-3704101E73DF> /Users/USER/*/_typeconv.cpython-39-darwin.so
   0x12309a000 -        0x12309dff7 +_nrt_python.cpython-39-darwin.so (0) <1D5D5D46-7B9B-3EA5-8197-0C4C88F3D0DC> /Users/USER/*/_nrt_python.cpython-39-darwin.so
   0x1230ac000 -        0x123175ff7  com.apple.AMDRadeonX4000GLDriver (2.11.20 - 2.1.1) <0AD1C812-DBC2-3949-82E6-7DAEE291ED76> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
   0x126ac2000 -        0x126b2c70f  dyld (655.1.1) <DFC3C4AF-6F97-3B34-B18D-7DCB23F2A83A> /usr/lib/dyld
   0x12c9d5000 -        0x12c9deff3 +math.cpython-39-darwin.so (0) <F46E3E43-054C-3CA5-8307-A6142B94A32B> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
   0x12d1e8000 -        0x12d1eeffb +_json.cpython-39-darwin.so (0) <BB76DCE0-FD3C-3F04-B508-48FB89C26B82> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_json.cpython-39-darwin.so
   0x12d238000 -        0x12d24cff7 +zlib.cpython-39-darwin.so (0) <B0076825-749E-30E8-B071-DF83A9BCD8D6> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/zlib.cpython-39-darwin.so
   0x12d257000 -        0x12d26dff3 +_bz2.cpython-39-darwin.so (0) <433FFB4A-1470-3926-8DE7-B18DBC8AAB9B> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_bz2.cpython-39-darwin.so
   0x12d278000 -        0x12d2a7ffb +_lzma.cpython-39-darwin.so (0) <B9BC59A5-E743-37D5-B02A-EFA4F15EA85F> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_lzma.cpython-39-darwin.so
   0x12d2f5000 -        0x12d2f6fff +_bisect.cpython-39-darwin.so (0) <47EA50C8-1887-318D-A4A7-BC412A138817> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_bisect.cpython-39-darwin.so
   0x12d2fe000 -        0x12d2ffff7 +_random.cpython-39-darwin.so (0) <145539A2-4FC7-35D3-9409-ACF96388896D> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_random.cpython-39-darwin.so
   0x12d308000 -        0x12d30cff7 +_sha512.cpython-39-darwin.so (0) <42169AA4-1F3D-34AA-A50C-FA2F17E3F413> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_sha512.cpython-39-darwin.so
   0x12d314000 -        0x12d31cff7 +binascii.cpython-39-darwin.so (0) <D2C999CF-F2C3-329D-A9DB-8B2E2ADF6C31> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/binascii.cpython-39-darwin.so
   0x12d365000 -        0x12d36aff7 +_struct.cpython-39-darwin.so (0) <6AE12DF5-840D-3B7D-A868-5E66C092D9F8> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_struct.cpython-39-darwin.so
   0x12d448000 -        0x12d724913 +_ssl.cpython-39-darwin.so (0) <A80D91D8-6E39-3A32-B449-0E6C7B6E3164> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_ssl.cpython-39-darwin.so
   0x12d7f5000 -        0x12d802ffb +_socket.cpython-39-darwin.so (0) <2DFB0814-B50F-3C05-B5EF-F2FB58CF81A8> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
   0x12d88f000 -        0x12d893ffb +select.cpython-39-darwin.so (0) <B2501CCF-DBF7-3E32-8B64-409D3B2F73A2> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
   0x12d89d000 -        0x12d8a4ffb +array.cpython-39-darwin.so (0) <D6108EB5-C628-38CB-9BBB-FF24D36D1DFA> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
   0x12d940000 -        0x12d94fff3 +_datetime.cpython-39-darwin.so (0) <88796DEB-94DB-3B37-902B-5A7C5168799B> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_datetime.cpython-39-darwin.so
   0x12d9e0000 -        0x12dc2107b +_hashlib.cpython-39-darwin.so (0) <0CC5B457-B403-36D4-A2A2-525B7606CBA9> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_hashlib.cpython-39-darwin.so
   0x12dcbf000 -        0x12dcc5ff7 +_blake2.cpython-39-darwin.so (0) <B0E1F116-41C6-3F17-A396-9E6297C1E133> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_blake2.cpython-39-darwin.so
   0x12dd0f000 -        0x12dd10fff +_queue.cpython-39-darwin.so (0) <EDD83AB2-AAB5-354A-9062-EB3A4574FB09> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_queue.cpython-39-darwin.so
   0x12df07000 -        0x12e012fff +unicodedata.cpython-39-darwin.so (0) <F261362D-0AE0-3EED-A177-4BCD5E748410> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/unicodedata.cpython-39-darwin.so
   0x12e17f000 -        0x12e4f4fe7 +_multiarray_umath.cpython-39-darwin.so (0) <495E23F2-DD86-34BE-85F2-D8B8FA1CFDFE> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/core/_multiarray_umath.cpython-39-darwin.so
   0x12e61c000 -        0x1321c3b4f +libopenblas.0.dylib (0) <03CB01A7-1E7B-3A87-B36F-CD619D546D98> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/.dylibs/libopenblas.0.dylib
   0x132460000 -        0x132577ff7 +libgfortran.3.dylib (0) <9ABE5EDE-AD43-391A-9E54-866711FAC32A> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/.dylibs/libgfortran.3.dylib
   0x1325e4000 -        0x13261afff +libquadmath.0.dylib (0) <7FFA409F-FB04-3B64-BE9A-3E3A494C975E> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/.dylibs/libquadmath.0.dylib
   0x13262e000 -        0x132643ff7 +libgcc_s.1.dylib (0) <7C6D7CB7-82DB-3290-8181-07646FEA1F80> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/.dylibs/libgcc_s.1.dylib
   0x15a693000 -        0x15a6aaffb +_pickle.cpython-39-darwin.so (0) <56495CB2-861A-38F5-BB18-48864C6E1C9E> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_pickle.cpython-39-darwin.so
   0x15a7bb000 -        0x15a7c8ff7 +_multiarray_tests.cpython-39-darwin.so (0) <AE0DCAB5-64AB-3F7D-B12A-60B9B9E919FF> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/core/_multiarray_tests.cpython-39-darwin.so
   0x15a81f000 -        0x15a833f2f +_ctypes.cpython-39-darwin.so (0) <0B4CA173-F03A-3878-B674-EFD33BEBE2E8> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_ctypes.cpython-39-darwin.so
   0x15a8ca000 -        0x15a8cbffb +lapack_lite.cpython-39-darwin.so (0) <ED8E8882-7728-3AFC-B16E-AD65D26C95CC> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/linalg/lapack_lite.cpython-39-darwin.so
   0x15a8d3000 -        0x15a8ecffb +_umath_linalg.cpython-39-darwin.so (0) <C031BBC1-676E-3561-971A-817DB290B4CC> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/linalg/_umath_linalg.cpython-39-darwin.so
   0x15a980000 -        0x15a9c4ffb +_decimal.cpython-39-darwin.so (0) <05BE5683-1935-39D2-9963-6592558C8836> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_decimal.cpython-39-darwin.so
   0x15aa23000 -        0x15aa34fff +_pocketfft_internal.cpython-39-darwin.so (0) <F874775F-892F-3E6D-AB44-13585A46F440> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/fft/_pocketfft_internal.cpython-39-darwin.so
   0x15aa7d000 -        0x15aaeefff +mtrand.cpython-39-darwin.so (0) <26C3326C-CD5C-3EB6-ADC1-1501DEFF4824> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/mtrand.cpython-39-darwin.so
   0x15ab49000 -        0x15ab67ffb +bit_generator.cpython-39-darwin.so (0) <0AA58188-F7BE-3259-B73D-F73A44D18892> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/bit_generator.cpython-39-darwin.so
   0x15ab87000 -        0x15abbcff3 +_common.cpython-39-darwin.so (0) <A5274DC2-1EDF-3596-810F-949AFC3280AF> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_common.cpython-39-darwin.so
   0x15abd9000 -        0x15ac2fffb +_bounded_integers.cpython-39-darwin.so (0) <C5EA861D-2A70-3753-B812-574045E67644> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_bounded_integers.cpython-39-darwin.so
   0x15ac56000 -        0x15ac64ffb +_mt19937.cpython-39-darwin.so (0) <317BAC67-09BA-3FCD-951A-1F8665EB2AB2> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_mt19937.cpython-39-darwin.so
   0x15ac74000 -        0x15ac80ff3 +_philox.cpython-39-darwin.so (0) <E0D66351-2EA3-3CAC-92B8-9BDD75A35465> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_philox.cpython-39-darwin.so
   0x15ac90000 -        0x15ac9aff7 +_pcg64.cpython-39-darwin.so (0) <97A10DFD-6916-3251-84B1-FCCF8D908E08> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_pcg64.cpython-39-darwin.so
   0x15aca9000 -        0x15acb0fff +_sfc64.cpython-39-darwin.so (0) <4A390EEB-7105-3235-85B2-4C8D98B3587C> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_sfc64.cpython-39-darwin.so
   0x15acbd000 -        0x15ad43ffb +_generator.cpython-39-darwin.so (0) <D25A4A84-E711-357E-9925-2B76BD03BAB0> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/site-packages/numpy/random/_generator.cpython-39-darwin.so
   0x162f63000 -        0x162f63ff7 +_opcode.cpython-39-darwin.so (0) <214C6B22-487E-3A65-A490-5B33498478EA> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_opcode.cpython-39-darwin.so
   0x162feb000 -        0x163017fff +pyexpat.cpython-39-darwin.so (0) <4A3E67EA-E7A4-3AE2-87F5-46063A70A68A> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/pyexpat.cpython-39-darwin.so
   0x16316f000 -        0x16316fffb +_uuid.cpython-39-darwin.so (0) <8E769385-6E26-3F37-A749-D798D8F0623D> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_uuid.cpython-39-darwin.so
   0x163176000 -        0x163177ff3 +_multiprocessing.cpython-39-darwin.so (0) <B761C7A4-BA22-3CAD-805F-2E5549E7CB0D> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_multiprocessing.cpython-39-darwin.so
   0x1631b0000 -        0x1631b0fff +_contextvars.cpython-39-darwin.so (0) <150E6EDE-76AB-3B5C-B2E0-27EF500C13F2> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_contextvars.cpython-39-darwin.so
   0x1631b8000 -        0x1631bafff +_internal.cpython-39-darwin.so (0) <9A862218-A34F-393F-9807-EB3FE5DD1825> /Users/USER/*/_internal.cpython-39-darwin.so
   0x1635df000 -        0x1635e5ff3 +cmath.cpython-39-darwin.so (0) <827C7AEB-AA7C-3508-A4F5-C2B093E1DC75> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/cmath.cpython-39-darwin.so
   0x164146000 -        0x16414effb +_asyncio.cpython-39-darwin.so (0) <5B8AA0B7-1E98-34B9-BF8B-BE377AA3EE5A> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_asyncio.cpython-39-darwin.so
   0x1645e4000 -        0x1645e4ffb +_statistics.cpython-39-darwin.so (0) <B95B6431-4531-33D9-82DB-66669A8D2B04> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_statistics.cpython-39-darwin.so
   0x16461b000 -        0x16461dff7 +_lsprof.cpython-39-darwin.so (0) <056B7F3C-B1A6-3363-B274-72155429686C> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_lsprof.cpython-39-darwin.so
   0x1649db000 -        0x167257fff +libllvmlite.dylib (0) <D41DB033-9219-375A-BD43-2BF0EF59A46B> /Users/USER/*/libllvmlite.dylib
   0x167f21000 -        0x167f4fff7 +_helperlib.cpython-39-darwin.so (0) <2F0FA90B-BC60-352B-B3C3-C5D12E09EDDC> /Users/USER/*/_helperlib.cpython-39-darwin.so
   0x16885e000 -        0x169b9bfff +pyluxcore.so (0) <F2664862-8F6B-3921-948D-2A17B26EA15B> /Users/USER/Library/Application Support/Blender/*/pyluxcore.so
   0x16a511000 -        0x16a583ff7 +libomp.dylib (0) <C2FE28E0-2062-32E3-9C52-451578776A98> /Users/USER/Library/Application Support/Blender/*/libomp.dylib
   0x16a5ba000 -        0x16c0c6fe7 +libembree3.3.dylib (3) <7A7B4D39-2866-310A-8ABE-CBB5A7324B34> /Users/USER/Library/Application Support/Blender/*/libembree3.3.dylib
   0x16c1fa000 -        0x16c57bfef +libOpenImageDenoise.1.4.0.dylib (0) <1BE2C9AC-0E63-3F4C-9601-2D653DDDE0C7> /Users/USER/Library/Application Support/Blender/*/libOpenImageDenoise.1.4.0.dylib
   0x16f2b2000 -        0x16f2fdff7 +libtbb.dylib (0) <31CCAC37-6247-3C6F-A906-78C2DF983935> /Users/USER/Library/Application Support/Blender/*/libtbb.dylib
   0x16f34e000 -        0x16f3cbff7 +libtiff.5.dylib (0) <C5918C14-C818-3A25-92BE-B43F328001CD> /Users/USER/Library/Application Support/Blender/*/libtiff.5.dylib
   0x16f3e1000 -        0x17017cffb +libOpenImageIO.2.2.dylib (0) <6450F8F5-9C29-3282-8978-D3D5DF614011> /Users/USER/Library/Application Support/Blender/*/libOpenImageIO.2.2.dylib
   0x1707c0000 -        0x1707f0fef +libtbbmalloc.dylib (0) <5A595F05-10A6-3592-90AA-8C7B490B6163> /Users/USER/Library/Application Support/Blender/*/libtbbmalloc.dylib
   0x170c5a000 -        0x170c5effb +_csv.cpython-39-darwin.so (0) <3BDC81E2-E161-3CD2-B593-6AE86873AAEE> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_csv.cpython-39-darwin.so
   0x170c68000 -        0x170da2ffb +_sqlite3.cpython-39-darwin.so (0) <29720316-2D7A-318E-82D6-9D368FCCF498> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_sqlite3.cpython-39-darwin.so
   0x1712cb000 -        0x1712cffff +_multibytecodec.cpython-39-darwin.so (0) <91E7F322-24EA-3A43-8BFC-54AC08CAE16B> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_multibytecodec.cpython-39-darwin.so
   0x17141c000 -        0x17141cff7 +_posixshmem.cpython-39-darwin.so (0) <99849014-1AED-3C0D-8E20-063C5DE0C382> /Applications/Blender 2.93.4.app/Contents/Resources/2.93/python/lib/python3.9/lib-dynload/_posixshmem.cpython-39-darwin.so
0x7fff31f85000 -     0x7fff322defff  com.apple.RawCamera.bundle (8.15.0 - 1031.4.4) <AB6E8A8F-0BFE-37EE-A135-44ABA4FCB559> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff322e1000 -     0x7fff323edfff  com.apple.AMDMTLBronzeDriver (2.11.20 - 2.1.1) <1D8E8E3B-88F4-35B1-8E83-AE74B558C26C> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff323ee000 -     0x7fff32d93ff3  ATIRadeonX4000SCLib.dylib (2.11.20) <13C8B1DC-87F9-3F99-88E8-F7719F98D99E> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff39c07000 -     0x7fff39c07fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <762942CB-CFC9-3A0C-9645-A56523A06426> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff39c08000 -     0x7fff39c1eff7  libCGInterfaces.dylib (506.22) <1B6C92D9-F4B8-37BA-9635-94C4A56098CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff39c1f000 -     0x7fff3a2b8fef  com.apple.vImage (8.1 - ???) <53FA3611-894E-3158-A654-FBD2F70998FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff3a2b9000 -     0x7fff3a532ff3  libBLAS.dylib (1243.200.4) <417CA0FC-B6CB-3FB3-ACBC-8914E3F62D20> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff3a533000 -     0x7fff3a5a5ffb  libBNNS.dylib (38.250.1) <538D12A2-9B9D-3E22-9896-F90F6E69C06E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff3a5a6000 -     0x7fff3a94fff3  libLAPACK.dylib (1243.200.4) <92175DF4-863A-3780-909A-A3E5C410F2E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3a950000 -     0x7fff3a965feb  libLinearAlgebra.dylib (1243.200.4) <CB671EE6-DEA1-391C-9B2B-AA09A46B4D7A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff3a966000 -     0x7fff3a96bff3  libQuadrature.dylib (3.200.2) <1BAE7E22-2862-379F-B334-A3756067730F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff3a96c000 -     0x7fff3a9e8ff3  libSparse.dylib (79.200.5) <E78B33D3-672A-3C53-B512-D3DDB2E9AC8D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff3a9e9000 -     0x7fff3a9fcfe3  libSparseBLAS.dylib (1243.200.4) <E9243341-DB77-37C1-97C5-3DFA00DD70FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff3a9fd000 -     0x7fff3abe4ff7  libvDSP.dylib (671.250.4) <7B110627-A9C1-3FB7-A077-0C7741BA25D8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff3abe5000 -     0x7fff3ac98ff7  libvMisc.dylib (671.250.4) <D5BA4812-BFFC-3CD0-B382-905CD8555DA6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff3ac99000 -     0x7fff3ac99fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <74288115-EF61-30B6-843F-0593B31D4929> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff3ae3b000 -     0x7fff3bbf0ffb  com.apple.AppKit (6.9 - 1671.60.107) <2F7E5984-E89A-3451-A3DF-FAAA509CF884> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3bc42000 -     0x7fff3bc42fff  com.apple.ApplicationServices (50.1 - 50.1) <84097DEB-E2FC-3901-8DD7-A670EA2274E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3bc43000 -     0x7fff3bcaefff  com.apple.ApplicationServices.ATS (377 - 453.11.2.2) <A258DA73-114B-3102-A056-4AAAD3CEB9DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff3bd47000 -     0x7fff3be5efff  libFontParser.dylib (228.6.2.3) <3602D55B-3B9E-3B3A-A814-08C1244A8AE4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff3be5f000 -     0x7fff3bea1fff  libFontRegistry.dylib (228.12.2.3) <2A56347B-2809-3407-A8B4-2AB88E484062> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3befb000 -     0x7fff3bf2dfff  libTrueTypeScaler.dylib (228.6.2.3) <7E4C5D9C-51AF-3EC1-8FA5-11CD4BEE477A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff3bf92000 -     0x7fff3bf96ff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <C0D9E23C-ABA0-39DE-A4EB-5A41C5499056> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff3c031000 -     0x7fff3c083ff7  com.apple.HIServices (1.22 - 628) <2BE461FF-80B9-30D3-A574-AED5724B1C1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3c084000 -     0x7fff3c093fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <F5617A2A-FEA6-3832-B5BA-C2111B98786F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3c094000 -     0x7fff3c0ddff7  com.apple.print.framework.PrintCore (14.2 - 503.8) <57C2FE32-0E74-3079-B626-C2D52F2D2717> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff3c0de000 -     0x7fff3c117ff7  com.apple.QD (3.12 - 407.2) <28C7D39F-59C9-3314-BECC-67045487229C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff3c118000 -     0x7fff3c124fff  com.apple.speech.synthesis.framework (8.1.3 - 8.1.3) <5E7B9BD4-122B-3012-A044-3259C97E7509> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff3c125000 -     0x7fff3c39cff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <04F482F1-E1C1-3955-8A6C-8AA152AA06F3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff3c39e000 -     0x7fff3c39efff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <ABC54269-002D-310D-9654-46CF960F863E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff3c6f7000 -     0x7fff3ca98fff  com.apple.CFNetwork (978.0.7 - 978.0.7) <B2133D0D-1399-3F17-80F0-313E3A241C89> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff3caad000 -     0x7fff3caadfff  com.apple.Carbon (158 - 158) <56AD06AA-7BB4-3F0B-AEF7-9768D0BC1C98> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3caae000 -     0x7fff3cab1ffb  com.apple.CommonPanels (1.2.6 - 98) <1CD6D56D-8EC7-3528-8CBC-FC69533519B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3cab2000 -     0x7fff3cda9fff  com.apple.HIToolbox (2.1.1 - 918.7) <13F69D4C-D19F-3E09-9231-1978D783A556> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3cdaa000 -     0x7fff3cdadff3  com.apple.help (1.3.8 - 66) <A08517EB-8958-36C9-AEE0-1A8FEEACBE3F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff3cdae000 -     0x7fff3cdb3ff7  com.apple.ImageCapture (9.0 - 1534.2) <DB063E87-ED8F-3E4E-A7E2-A6B45FA73EF7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3cdb4000 -     0x7fff3ce49ff3  com.apple.ink.framework (10.9 - 225) <7C7E9483-2E91-3DD3-B1E0-C238F42CA0DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3ce4a000 -     0x7fff3ce62ff7  com.apple.openscripting (1.7 - 179.1) <9B8C1ECC-5864-3E21-9149-863E884EA25C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff3ce82000 -     0x7fff3ce83ff7  com.apple.print.framework.Print (14.2 - 267.4) <A7A9D2A0-D4E0-35EF-A0F7-50521F707C33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3ce84000 -     0x7fff3ce86ff7  com.apple.securityhi (9.0 - 55006) <05717F77-7A7B-37E6-AB3E-03F063E9095B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3ce87000 -     0x7fff3ce8dff7  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3CC050FB-EBCB-3087-8EA5-F378C8F99217> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3cfaf000 -     0x7fff3cfaffff  com.apple.Cocoa (6.11 - 23) <8D092DD2-0CA4-34C9-872C-8BBFAE1995A4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff3cfbd000 -     0x7fff3d10cff7  com.apple.ColorSync (4.13.0 - 3345.6) <31648BB6-7239-3D0E-81B1-BCF51FEF557F> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3d298000 -     0x7fff3d31efff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <1E8E64E6-0E58-375A-97F7-07CB4EE181AC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff3d382000 -     0x7fff3d3acffb  com.apple.CoreBluetooth (1.0 - 1) <A73F1709-DD18-3052-9F22-C0015278834B> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3d3ad000 -     0x7fff3d732fef  com.apple.CoreData (120 - 866.6) <132CB39B-8D58-30FA-B8AD-49BFFF34B293> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff3d733000 -     0x7fff3d823ff7  com.apple.CoreDisplay (101.3 - 110.18) <0EB2A997-FCAD-3D17-B140-9829961E5327> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff3d824000 -     0x7fff3dc68fe7  com.apple.CoreFoundation (6.9 - 1575.19) <B2850F42-CE01-3156-B121-FD4777290C8F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3dc6a000 -     0x7fff3e2f9fff  com.apple.CoreGraphics (2.0 - 1265.9) <BC95B558-EF77-3A57-A0BC-11606C778991> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3e2fb000 -     0x7fff3e61bfff  com.apple.CoreImage (14.4.0 - 750.0.140) <11026E39-D2FF-3CF6-8ACE-7BA293F9853E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3e918000 -     0x7fff3ea1cfff  com.apple.CoreMedia (1.0 - 2290.13) <A739B93D-23C2-3A34-8D61-6AC924B9634F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff3ea79000 -     0x7fff3ea79fff  com.apple.CoreServices (946 - 946) <6EC9F377-EBD8-3358-92D1-6586F6F1E8E9> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff3ea7a000 -     0x7fff3eaf6ff7  com.apple.AE (773 - 773) <55AE7C9E-27C3-30E9-A047-3B92A6FD53B4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3eaf7000 -     0x7fff3edcefff  com.apple.CoreServices.CarbonCore (1178.33 - 1178.33) <CB87F0C7-2CD6-3983-8E32-B6A2EC925352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3edcf000 -     0x7fff3ee17ff7  com.apple.DictionaryServices (1.2 - 284.16.4) <746EB200-DC51-30AE-9CBC-608A7B4CC8DA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3ee18000 -     0x7fff3ee20ffb  com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <8406D379-8D33-3611-861B-7ABD26DB50D2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff3ee21000 -     0x7fff3efd2ff7  com.apple.LaunchServices (946 - 946) <A0C91634-9410-38E8-BC11-7A5A369E6BA5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3efd3000 -     0x7fff3f071ff7  com.apple.Metadata (10.7.0 - 1191.57) <BFFAED00-2560-318A-BB8F-4E7E5123EC61> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3f072000 -     0x7fff3f0bcff7  com.apple.CoreServices.OSServices (946 - 946) <20C4EEF8-D5AC-39A0-9B4A-78F88E3EFBCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3f0bd000 -     0x7fff3f124ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <DA08AA6F-A6F1-36C0-87F4-E26294E51A3A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3f125000 -     0x7fff3f146ff3  com.apple.coreservices.SharedFileList (71.28 - 71.28) <487A8464-729E-305A-B5D1-E3FE8EB9CFC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3f451000 -     0x7fff3f5b3ff3  com.apple.CoreText (352.0 - 584.26.3.2) <59919B0C-CBD5-3877-8D6F-D6048F1E5F42> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3f5b4000 -     0x7fff3f5f4ff3  com.apple.CoreVideo (1.8 - 281.4) <10CF8E52-07E3-382B-8091-2CEEEFFA69B4> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3f5f5000 -     0x7fff3f684fff  com.apple.framework.CoreWLAN (13.0 - 1375.2) <BF4B29F7-FBC8-3299-98E8-C3F8C04B7C92> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3f8db000 -     0x7fff3f8e0ffb  com.apple.DiskArbitration (2.7 - 2.7) <F481F2C0-884E-3265-8111-ABBEC93F0920> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3faa3000 -     0x7fff3faa5ff3  com.apple.ForceFeedback (1.0.6 - 1.0.6) <205B0C3E-4E8D-3347-A993-469F06ABBFF9> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
0x7fff3faa6000 -     0x7fff3fe53ffb  com.apple.Foundation (6.9 - 1575.19) <A85BF812-B784-36B9-89BB-E29772B0708C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3fec2000 -     0x7fff3fef1ffb  com.apple.GSS (4.0 - 2.0) <E2B90D08-3857-3155-9FCC-07D778988EC9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3fff1000 -     0x7fff400fbfff  com.apple.Bluetooth (6.0.14 - 6.0.14d3) <C2D1A774-2390-363D-8215-BF51FFCB6CCA> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff4015e000 -     0x7fff401edfff  com.apple.framework.IOKit (2.0.2 - 1483.260.4) <8A90F547-86EF-3DFB-92FE-0E2C0376DD84> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff401ef000 -     0x7fff401feffb  com.apple.IOSurface (255.6.1 - 255.6.1) <85F85EBB-EA59-3A8B-B3EB-7C20F3CC77AE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff40252000 -     0x7fff403ddfef  com.apple.ImageIO.framework (3.3.0 - 1850.2) <75E46A31-D87D-35CE-86A4-96A50971FDB2> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff403de000 -     0x7fff403e2ffb  libGIF.dylib (1850.2) <4774EBDF-583B-3DDD-A0E1-9F427CB6A074> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff403e3000 -     0x7fff404bffef  libJP2.dylib (1850.2) <697BB77F-A682-339F-8659-35432962432D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff404c0000 -     0x7fff404e5feb  libJPEG.dylib (1850.2) <171A8AC4-AADA-376F-9F2C-B9C978DB1007> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff407a8000 -     0x7fff407cefeb  libPng.dylib (1850.2) <FBCEE909-F573-3AD6-A45F-AF32612BF8A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff407cf000 -     0x7fff407d1ffb  libRadiance.dylib (1850.2) <56907025-D5CE-3A9E-ACCB-A376C2599853> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff407d2000 -     0x7fff4081ffe7  libTIFF.dylib (1850.2) <F59557C9-C761-3E6F-85D1-0FBFFD53ED5C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff41992000 -     0x7fff419abfff  com.apple.Kerberos (3.0 - 1) <DB1E0679-37E1-3B93-9789-32F63D660C3B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff41c65000 -     0x7fff41c6ffff  com.apple.MediaAccessibility (1.0 - 114.4) <76C449C5-DB45-3D7F-BFAD-3DACEF15DA21> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff41d1f000 -     0x7fff423c5fff  com.apple.MediaToolbox (1.0 - 2290.13) <71BB5D76-34CA-3A30-AECF-24BE29FCC275> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff423c7000 -     0x7fff4246fff7  com.apple.Metal (162.2 - 162.2) <FFF7DFF3-7C4E-32C6-A0B5-C356079D3B7C> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4248b000 -     0x7fff424aaff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <44CE8362-E972-3697-AD6F-15BC863BAEB8> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff424ab000 -     0x7fff42527fe7  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <EE8440DA-66DF-3923-ABBC-E0543211C069> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff42528000 -     0x7fff4254ffff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <E64450DF-2B96-331E-B7F4-666E00571C70> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff42550000 -     0x7fff4267bff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <F2CF26B6-73F1-3644-8FE9-CDB9B2C4501F> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff4267c000 -     0x7fff42696fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B33A35C3-0393-366B-ACFB-F4BB6A5F7B4A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff42697000 -     0x7fff42698ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <69F14BCF-C5C5-3BF8-9C31-8F87D2D6130A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff4348f000 -     0x7fff4349bff7  com.apple.NetFS (6.0 - 4.0) <E917806F-0607-3292-B2D6-A15404D61B99> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff437fe000 -     0x7fff43821ff7  com.apple.audio.OpenAL (1.8 - 1.8) <2EE5236C-775B-36B1-97A8-DEE5FB80F5B5> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x7fff45f30000 -     0x7fff45f38fe3  libcldcpuengine.dylib (2.11) <AAE49359-EB53-3FD4-ADBF-C60498BD0B34> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff45f39000 -     0x7fff45f90ff7  com.apple.opencl (2.15.3 - 2.15.3) <056BAD8A-23BC-3F74-9E2C-3AC81E7DEA5A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff45f91000 -     0x7fff45facff7  com.apple.CFOpenDirectory (10.14 - 207.200.4) <F03D84EB-49B2-3A00-9127-B9A269824026> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff45fad000 -     0x7fff45fb8ffb  com.apple.OpenDirectory (10.14 - 207.200.4) <A8020CEE-5B78-3581-A735-EA2833683F31> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff46908000 -     0x7fff4690afff  libCVMSPluginSupport.dylib (17.7.3) <8E051EA7-55B6-3DF1-9821-72C391DE953B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff4690b000 -     0x7fff46910ff3  libCoreFSCache.dylib (166.2) <222C2A4F-7E32-30F6-8459-2FAB98073A3D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff46911000 -     0x7fff46915fff  libCoreVMClient.dylib (166.2) <6789ECD4-91DD-32EF-A1FD-F27D2344CD8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff46916000 -     0x7fff4691eff7  libGFXShared.dylib (17.7.3) <8C50BF27-B525-3B23-B86C-F444ADF97851> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff4691f000 -     0x7fff4692afff  libGL.dylib (17.7.3) <2AC457EA-1BD3-3C8E-AFAB-7EA6234EB749> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff4692b000 -     0x7fff46965fef  libGLImage.dylib (17.7.3) <AA027AFA-C115-3861-89B2-0AE946838952> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff46966000 -     0x7fff46ad8ff7  libGLProgrammability.dylib (17.7.3) <5BB795C6-97AB-37AC-954C-145E3216AC3B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff46ad9000 -     0x7fff46b17fff  libGLU.dylib (17.7.3) <CB3B0579-D9A2-3CA5-8942-0C8344FAD054> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff474b4000 -     0x7fff474c3ffb  com.apple.opengl (17.7.3 - 17.7.3) <94B5CF34-5BD6-3652-9A8C-E9C56E0A9FB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff474c4000 -     0x7fff4765bff7  GLEngine (17.7.3) <B2CB8E1E-4AD3-3CE4-ACB0-89A6749603D1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff4765c000 -     0x7fff47685ff3  GLRendererFloat (17.7.3) <A656F9C6-AB06-33C6-842A-600CB8B060C6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff482c6000 -     0x7fff4851dff7  com.apple.QuartzCore (1.11 - 701.14) <33E846BE-1794-3186-9BF2-6ADF62C782A3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff48d53000 -     0x7fff49053fff  com.apple.security (7.0 - 58286.270.3.0.1) <DF7677A7-9765-3B6A-9D1C-3589145E4B65> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff49054000 -     0x7fff490e0fff  com.apple.securityfoundation (6.0 - 55185.260.1) <1EE899E6-222A-3526-B505-B0D0B6FA042A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff49112000 -     0x7fff49116fff  com.apple.xpc.ServiceManagement (1.0 - 1) <FCF7BABA-DDDD-3770-8DAC-7069850203C2> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff494af000 -     0x7fff4951cfff  com.apple.SystemConfiguration (1.17 - 1.17) <30C8327F-3EFF-3520-9C50-016F8B6B954F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4977b000 -     0x7fff49adcfff  com.apple.VideoToolbox (1.0 - 2290.13) <7FCB2FC0-EFB8-37C2-B0D3-60AE9FDFE230> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4c758000 -     0x7fff4c7fdfeb  com.apple.APFS (1.0 - 1) <2D22485D-552D-3CB6-9FE1-38547597918F> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4d212000 -     0x7fff4d213ff7  com.apple.AggregateDictionary (1.0 - 1) <A6AF8AC4-1F25-37C4-9157-A02E9C200926> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4d817000 -     0x7fff4d843ff7  com.apple.framework.Apple80211 (13.0 - 1380.2) <16F093EF-370B-3B90-8DB4-E94624431D15> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff4d96b000 -     0x7fff4d97afc7  com.apple.AppleFSCompression (96.200.3 - 1.0) <3CF60CE8-976E-3CB8-959D-DD0948C1C2DE> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff4da76000 -     0x7fff4da81fff  com.apple.AppleIDAuthSupport (1.0 - 1) <2E9D1398-DBE6-328B-ADDA-20FA5FAD7405> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff4dac2000 -     0x7fff4db0bff3  com.apple.AppleJPEG (1.0 - 1) <4C1F426B-7D77-3980-9633-7DBD8C666B9A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff4dd5f000 -     0x7fff4dd81fff  com.apple.applesauce (1.0 - ???) <F49107C7-3C51-3024-8EF1-C57643BE4F3B> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff4de45000 -     0x7fff4de95ff7  com.apple.AppleVAFramework (5.1.4 - 5.1.4) <3399D678-8741-3B70-B8D0-7C63C8ACF7DF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff4dee0000 -     0x7fff4def4ffb  com.apple.AssertionServices (1.0 - 1) <456E507A-4561-3628-9FBE-173ACE7429D8> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff4e2c3000 -     0x7fff4e3afff7  com.apple.AuthKit (1.0 - 1) <2765ABE9-54F2-3E45-8A93-1261E251B90D> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff4e571000 -     0x7fff4e579fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <2A396FC0-7B79-3088-9A82-FB93C1181A57> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff4e57a000 -     0x7fff4e60ffff  com.apple.backup.framework (1.10.5 - ???) <4EEC51E2-AE4C-340A-B686-901810152C12> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff4e610000 -     0x7fff4e67dff3  com.apple.BaseBoard (360.28 - 360.28) <68FA8044-F3CD-3BC6-9DAB-27DACF52BFC0> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff502e8000 -     0x7fff502f1ffb  com.apple.CommonAuth (4.0 - 2.0) <93335CB6-ABEB-3EC7-A040-8A667F40D5F3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff5078a000 -     0x7fff50b6dfef  com.apple.CoreAUC (274.0.0 - 274.0.0) <C71F1581-E73B-3DA0-958B-E912C3FB3F23> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff50b6e000 -     0x7fff50b9cff7  com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <A04A99B8-DAC5-36FC-BAC7-7431600C1F89> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff50fca000 -     0x7fff50fdbff7  com.apple.CoreEmoji (1.0 - 69.19.9) <228457B3-E191-356E-9A5B-3C0438D05FBA> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff51585000 -     0x7fff515ebff7  com.apple.CoreNLP (1.0 - 130.15.22) <27877820-17D0-3B02-8557-4014E876CCC7> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff51898000 -     0x7fff518a0ff7  com.apple.CorePhoneNumbers (1.0 - 1) <11F97C7E-C183-305F-8E6C-9B374F50E26B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff51a1c000 -     0x7fff51a4dff3  com.apple.CoreServicesInternal (358 - 358) <DD6EF60D-048F-3186-83DA-EB191EDF48AE> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff51e14000 -     0x7fff51e98fff  com.apple.CoreSymbolication (10.2 - 64490.25.1) <28B2FF2D-3FDE-3A20-B343-341E5BD4E22F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff51f28000 -     0x7fff52053ff7  com.apple.coreui (2.1 - 499.10) <A80F4B09-F940-346F-A9DF-4EFADD9220A8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff52054000 -     0x7fff521f4fff  com.apple.CoreUtils (5.9 - 590.16) <66CC50F7-766D-33E2-A388-4DE22840ADFB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff52248000 -     0x7fff522abff7  com.apple.framework.CoreWiFi (13.0 - 1375.2) <CA4B835A-27AC-3FAB-9F44-E48548EA2442> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff522ac000 -     0x7fff522bdff7  com.apple.CrashReporterSupport (10.13 - 938.26) <E93D84A6-891D-38EE-BB4F-E9CD681189B7> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff5234d000 -     0x7fff5235cfff  com.apple.framework.DFRFoundation (1.0 - 211.1) <E3F02F2A-2059-39CC-85DA-969676EB88EB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff5235d000 -     0x7fff52361ff7  com.apple.DSExternalDisplay (3.1 - 380) <787B9748-B120-3453-B8FE-61D9E363A9E0> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff523e2000 -     0x7fff52457ffb  com.apple.datadetectorscore (7.0 - 590.27) <06FB1A07-7AE6-3ADD-8E7E-41955FAB38E8> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff524a3000 -     0x7fff524e0ff7  com.apple.DebugSymbols (190 - 190) <6F4FAACA-E06B-38AD-A0C2-14EA5408A231> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff524e1000 -     0x7fff5261cff7  com.apple.desktopservices (1.13.5 - ???) <265C0E94-B8BF-3F58-8D68-EA001EEA0B15> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff53563000 -     0x7fff5397efff  com.apple.vision.FaceCore (3.3.4 - 3.3.4) <A576E2DA-BF6F-3B18-8FEB-324E5C5FA9BD> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff57232000 -     0x7fff57233fff  libmetal_timestamp.dylib (902.3.2) <05389463-AF2E-33E2-A14F-1416E4A30835> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff588c7000 -     0x7fff588d2ff7  libGPUSupportMercury.dylib (17.7.3) <36E3C5B1-15EB-3713-BC3A-31A3B074DD24> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff588d3000 -     0x7fff588d8fff  com.apple.GPUWrangler (3.50.12 - 3.50.12) <6C820ED9-F306-3978-B5B8-432AD97BBDAF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff596e4000 -     0x7fff596f3fff  com.apple.GraphVisualizer (1.0 - 5) <48D020B7-5938-3FAE-B468-E291AEE2C06F> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff59859000 -     0x7fff598cdffb  com.apple.Heimdal (4.0 - 2.0) <D97FCF19-EAD6-3E2F-BE88-F817E45CAE96> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5abc9000 -     0x7fff5abd2fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <EA04DC2A-F0C8-3471-9E59-BE8697050ADF> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff5abd3000 -     0x7fff5abdaffb  com.apple.IOAccelerator (404.14 - 404.14) <11A50171-C8AE-3BBC-9FB9-2A3313FFBD31> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5abde000 -     0x7fff5abf6fff  com.apple.IOPresentment (1.0 - 42.6) <6DFD9A6E-BF95-3A27-89E7-ACAA9E30D90A> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5af9e000 -     0x7fff5afcbff7  com.apple.IconServices (379 - 379) <7BAD562D-4FA3-3E11-863C-1EEBE2406D2C> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5b25e000 -     0x7fff5b270ff3  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <30CFE05C-4108-3879-AFAA-5BB02CBE190B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff5b28b000 -     0x7fff5b366ff7  com.apple.LanguageModeling (1.0 - 159.15.15) <3DE3CE61-542B-37B7-883E-4B9717CAC65F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5b367000 -     0x7fff5b3a3ff7  com.apple.Lexicon-framework (1.0 - 33.15.10) <4B5E843E-2809-3E70-9560-9254E2656419> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5b3aa000 -     0x7fff5b3affff  com.apple.LinguisticData (1.0 - 238.25) <F529B961-098C-3E4C-A3E9-9DA9BFA1B3F0> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5bbcd000 -     0x7fff5bbd0fff  com.apple.Mangrove (1.0 - 25) <537A5B2E-4C30-3CFD-8BDC-79F9A04AC327> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5c0a4000 -     0x7fff5c0ccff7  com.apple.spotlight.metadata.utilities (1.0 - 1191.57) <38BB1FB7-3336-384C-B71F-4D0D402EB606> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff5c0cd000 -     0x7fff5c15aff7  com.apple.gpusw.MetalTools (1.0 - 1) <CBE2176A-8048-3A9C-AFE4-13973D44C704> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5c171000 -     0x7fff5c18affb  com.apple.MobileAssets (1.0 - 437.250.3) <8BE5B3A0-8F3A-3FAE-9AFF-32836300183C> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5c36e000 -     0x7fff5c389ffb  com.apple.MobileKeyBag (2.0 - 1.0) <C7C5DD21-66DE-31D1-92D9-BBEEAAE156FB> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5c412000 -     0x7fff5c43cffb  com.apple.MultitouchSupport.framework (2450.1 - 2450.1) <42A23EC9-64A7-31C7-BF33-DF4412ED8A3F> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5c678000 -     0x7fff5c682fff  com.apple.NetAuth (6.2 - 6.2) <0D01BBE5-0269-310D-B148-D19DAE143DEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5cee3000 -     0x7fff5cf34ff3  com.apple.OTSVG (1.0 - ???) <5BF1A9EB-2694-3267-9514-A4EB3BEF4081> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff5e0cc000 -     0x7fff5e0dbff7  com.apple.PerformanceAnalysis (1.218.2 - 218.2) <65F3DB3E-6D4E-33A0-B510-EF768D323DAB> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5ff6d000 -     0x7fff5ff8bff7  com.apple.ProtocolBuffer (1 - 263.2) <907D6C95-D050-31DE-99CA-16A5135BC6F9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff60123000 -     0x7fff60173fff  com.apple.ROCKit (27.6 - 27.6) <756C2253-E8B1-3C48-9945-DE8D6AD24DE2> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff602cd000 -     0x7fff602effff  com.apple.RemoteViewServices (2.0 - 128) <8FB0E4EB-DCBB-32E6-94C6-AA9BA9EE4CAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff61af9000 -     0x7fff61c17fff  com.apple.Sharing (1288.62 - 1288.62) <48B1F247-7910-3C16-814C-B99DE231F7F0> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff62a2b000 -     0x7fff62cdafff  com.apple.SkyLight (1.600.0 - 340.54) <90EB1C2E-B264-3EC4-AF7F-CDE7E7585746> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6347d000 -     0x7fff63489fff  com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <7A6A67DB-C813-328E-AAFB-D267A5B50B3D> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff63b28000 -     0x7fff63b64ff3  com.apple.StreamingZip (1.0 - 1) <046FAD5C-E0C5-3013-B1FE-24C018A0DDCF> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff63bda000 -     0x7fff63c65fc7  com.apple.Symbolication (10.2 - 64490.38.1) <9FDCC98D-5B32-35AD-A9BF-94DF2B78507F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff6414d000 -     0x7fff64159ffb  com.apple.TCC (1.0 - 1) <73CF6FA9-44CE-30C9-887F-235940976585> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff643bf000 -     0x7fff64487ff3  com.apple.TextureIO (3.8.4 - 3.8.1) <7CEAC05A-D283-3D5A-B1E3-C849285FA0BF> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff6453d000 -     0x7fff6453efff  com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <15DF9C73-54E4-3C41-BCF4-378338C55FB4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff64544000 -     0x7fff646fbffb  com.apple.UIFoundation (1.0 - 551.2) <917480B5-14BE-30E0-ABE6-9702336CC35A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff65377000 -     0x7fff65450fff  com.apple.ViewBridge (401.1 - 401.1) <18144EC1-5DEF-369C-8EBA-2826E7142784> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff65c28000 -     0x7fff65c2bfff  com.apple.dt.XCTTargetBootstrap (1.0 - 14490.66) <7AE3457F-AF40-3508-93FB-1D9E31EB1C9D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff6602c000 -     0x7fff6602effb  com.apple.loginsupport (1.0 - 1) <3F8D6334-BCD6-36C1-BA20-CC8503A84375> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff662f8000 -     0x7fff6632cfff  libCRFSuite.dylib (41.15.4) <406DAC06-0C77-3F90-878B-4D38F11F0256> /usr/lib/libCRFSuite.dylib
0x7fff6632f000 -     0x7fff66339ff7  libChineseTokenizer.dylib (28.15.3) <9B7F6109-3A5D-3641-9A7E-31D2239D73EE> /usr/lib/libChineseTokenizer.dylib
0x7fff663c7000 -     0x7fff663c8ffb  libDiagnosticMessagesClient.dylib (107) <A14D0819-0970-34CD-8680-80E4D7FE8C2C> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff663ff000 -     0x7fff66656ff3  libFosl_dynamic.dylib (18.3.4) <1B5DD4E2-8AE0-315E-829E-D5BFCD264EA8> /usr/lib/libFosl_dynamic.dylib
0x7fff666a7000 -     0x7fff666c6fff  libMobileGestalt.dylib (645.270.1) <99A06C8A-97D6-383D-862C-F453BABB48A4> /usr/lib/libMobileGestalt.dylib
0x7fff666c7000 -     0x7fff666c7fff  libOpenScriptingUtil.dylib (179.1) <4D603146-EDA5-3A74-9FF8-4F75D8BB9BC6> /usr/lib/libOpenScriptingUtil.dylib
0x7fff66807000 -     0x7fff66808ffb  libSystem.B.dylib (1252.250.1) <B1006948-7AD0-3CA9-81E0-833F4DD6BFB4> /usr/lib/libSystem.B.dylib
0x7fff66884000 -     0x7fff66885fff  libThaiTokenizer.dylib (2.15.1) <ADB37DC3-7D9B-3E73-A72A-BCC3433C937A> /usr/lib/libThaiTokenizer.dylib
0x7fff66897000 -     0x7fff668adffb  libapple_nghttp2.dylib (1.24.1) <6F04250A-6686-3FDC-9A8D-290C64B06502> /usr/lib/libapple_nghttp2.dylib
0x7fff668ae000 -     0x7fff668d7ffb  libarchive.2.dylib (54.250.1) <47289946-8504-3966-9127-6CE39993DC2C> /usr/lib/libarchive.2.dylib
0x7fff668d8000 -     0x7fff66957fff  libate.dylib (1.13.8) <92B44EDB-369D-3EE8-AEC5-61F8B9313DBF> /usr/lib/libate.dylib
0x7fff6695b000 -     0x7fff6695bff3  libauto.dylib (187) <3E3780E1-96F3-3A22-91C5-92F9A5805518> /usr/lib/libauto.dylib
0x7fff66a2b000 -     0x7fff66a3bffb  libbsm.0.dylib (39.200.18) <CF381E0B-025B-364F-A83D-2527E03F1AA3> /usr/lib/libbsm.0.dylib
0x7fff66a3c000 -     0x7fff66a49fff  libbz2.1.0.dylib (38.200.3) <272953A1-8D36-329B-BDDB-E887B347710F> /usr/lib/libbz2.1.0.dylib
0x7fff66a4a000 -     0x7fff66a9dff7  libc++.1.dylib (400.9.4) <9A60A190-6C34-339F-BB3D-AACE942009A4> /usr/lib/libc++.1.dylib
0x7fff66a9e000 -     0x7fff66ab3ff7  libc++abi.dylib (400.17) <38C09CED-9090-3719-90F3-04A2749F5428> /usr/lib/libc++abi.dylib
0x7fff66ab4000 -     0x7fff66ab4ff3  libcharset.1.dylib (51.200.6) <2A27E064-314C-359C-93FC-8A9B06206174> /usr/lib/libcharset.1.dylib
0x7fff66ab5000 -     0x7fff66ac5ffb  libcmph.dylib (6.15.1) <9C52B2FE-179F-32AC-B87E-2AFC49ABF817> /usr/lib/libcmph.dylib
0x7fff66ac6000 -     0x7fff66adeffb  libcompression.dylib (52.250.2) <7F4BB18C-1FB4-3825-8D8B-6E6B168774C6> /usr/lib/libcompression.dylib
0x7fff66d53000 -     0x7fff66d69fff  libcoretls.dylib (155.220.1) <4C64BE3E-41E3-3020-8BB7-07E90C0C861C> /usr/lib/libcoretls.dylib
0x7fff66d6a000 -     0x7fff66d6bff3  libcoretls_cfhelpers.dylib (155.220.1) <0959B3E9-6643-3589-8BB3-21D52CDF0EF1> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff66f09000 -     0x7fff67001ff7  libcrypto.35.dylib (22.260.1) <91C3D71A-4D1D-331D-89CC-67863DF10574> /usr/lib/libcrypto.35.dylib
0x7fff67217000 -     0x7fff6726dff3  libcups.2.dylib (462.12) <095619DC-9233-3937-9E50-5F10D917A40D> /usr/lib/libcups.2.dylib
0x7fff673a1000 -     0x7fff673a1fff  libenergytrace.dylib (17.200.1) <80BB567A-FD18-3497-BF97-353F57D98CDD> /usr/lib/libenergytrace.dylib
0x7fff673a2000 -     0x7fff673bbffb  libexpat.1.dylib (16.1.1) <28A385F1-4210-32D2-861B-C1B2189A5294> /usr/lib/libexpat.1.dylib
0x7fff673d3000 -     0x7fff673d8ff7  libgermantok.dylib (17.15.2) <E5F0F794-FF27-3D64-AE52-C78C6A84DD67> /usr/lib/libgermantok.dylib
0x7fff673d9000 -     0x7fff673deff7  libheimdal-asn1.dylib (520.270.1) <73F60D6F-76F8-35EF-9C86-9A81225EE4BE> /usr/lib/libheimdal-asn1.dylib
0x7fff67409000 -     0x7fff674f9fff  libiconv.2.dylib (51.200.6) <2047C9B7-3F74-3A95-810D-2ED8F0475A99> /usr/lib/libiconv.2.dylib
0x7fff674fa000 -     0x7fff6775bffb  libicucore.A.dylib (62141.0.1) <A0D63918-76E9-3C1B-B255-46F4C1DA7FE8> /usr/lib/libicucore.A.dylib
0x7fff677a8000 -     0x7fff677a9fff  liblangid.dylib (128.15.1) <22D05C4F-769B-3075-ABCF-44A0EBACE028> /usr/lib/liblangid.dylib
0x7fff677aa000 -     0x7fff677c2ff3  liblzma.5.dylib (10.200.3) <E1F4FD60-1CE4-37B9-AD95-29D348AF1AC0> /usr/lib/liblzma.5.dylib
0x7fff677da000 -     0x7fff6787eff7  libmecab.1.0.0.dylib (779.24.1) <A8D0379B-85FA-3B3D-89ED-5CF2C3826AB2> /usr/lib/libmecab.1.0.0.dylib
0x7fff6787f000 -     0x7fff67a83fff  libmecabra.dylib (779.24.1) <D71F71E0-30E2-3DB3-B636-7DE13D51FB4B> /usr/lib/libmecabra.dylib
0x7fff67c5b000 -     0x7fff67facff7  libnetwork.dylib (1229.250.15) <72C7E9E3-B2BE-3300-BE1B-64606222022C> /usr/lib/libnetwork.dylib
0x7fff6803e000 -     0x7fff687c3fdf  libobjc.A.dylib (756.2) <7C312627-43CB-3234-9324-4DEA92D59F50> /usr/lib/libobjc.A.dylib
0x7fff687d5000 -     0x7fff687d9ffb  libpam.2.dylib (22.200.1) <586CF87F-349C-393D-AEEB-FB75F94A5EB7> /usr/lib/libpam.2.dylib
0x7fff687dc000 -     0x7fff68811fff  libpcap.A.dylib (79.250.1) <C0893641-7DFF-3A33-BDAE-190FF54837E8> /usr/lib/libpcap.A.dylib
0x7fff6892a000 -     0x7fff68942ffb  libresolv.9.dylib (65.200.2) <893142A5-F153-3437-A22D-407EE542B5C5> /usr/lib/libresolv.9.dylib
0x7fff68993000 -     0x7fff68994ff7  libspindump.dylib (267.3) <A584E403-8C95-3841-9C16-E22664A5A63F> /usr/lib/libspindump.dylib
0x7fff68995000 -     0x7fff68b72fff  libsqlite3.dylib (274.26) <6404BA3B-BCA4-301F-B2FE-8776105A2AA3> /usr/lib/libsqlite3.dylib
0x7fff68d8b000 -     0x7fff68d8eff7  libutil.dylib (51.200.4) <CE9B18C9-66ED-32D4-9D29-01F8FCB467B0> /usr/lib/libutil.dylib
0x7fff68d8f000 -     0x7fff68d9cfff  libxar.1.dylib (417.1) <39CCF46B-C81A-34B1-92A1-58C4E5DA846E> /usr/lib/libxar.1.dylib
0x7fff68da1000 -     0x7fff68e83ff3  libxml2.2.dylib (32.10) <AA4E1B1F-0FDE-3274-9FA5-75446298D1AC> /usr/lib/libxml2.2.dylib
0x7fff68e84000 -     0x7fff68eacff3  libxslt.1.dylib (16.5) <E330D3A2-E32B-378A-973E-A8D245C0F712> /usr/lib/libxslt.1.dylib
0x7fff68ead000 -     0x7fff68ebfff7  libz.1.dylib (70.200.4) <B048FC1F-058F-3A08-A1FE-81D5308CB3E6> /usr/lib/libz.1.dylib
0x7fff696a3000 -     0x7fff696a7ff3  libcache.dylib (81) <1987D1E1-DB11-3291-B12A-EBD55848E02D> /usr/lib/system/libcache.dylib
0x7fff696a8000 -     0x7fff696b2ff3  libcommonCrypto.dylib (60118.250.2) <1765BB6E-6784-3653-B16B-CB839721DC9A> /usr/lib/system/libcommonCrypto.dylib
0x7fff696b3000 -     0x7fff696baff7  libcompiler_rt.dylib (63.4) <5212BA7B-B7EA-37B4-AF6E-AC4F507EDFB8> /usr/lib/system/libcompiler_rt.dylib
0x7fff696bb000 -     0x7fff696c4ff7  libcopyfile.dylib (146.250.1) <98CD00CD-9B91-3B5C-A9DB-842638050FA8> /usr/lib/system/libcopyfile.dylib
0x7fff696c5000 -     0x7fff69749fc3  libcorecrypto.dylib (602.260.2) <01464D24-570C-3B83-9D18-467769E0FCDD> /usr/lib/system/libcorecrypto.dylib
0x7fff697d0000 -     0x7fff69809ff7  libdispatch.dylib (1008.270.1) <97273678-E94C-3C8C-89F6-2E2020F4B43B> /usr/lib/system/libdispatch.dylib
0x7fff6980a000 -     0x7fff69836ff7  libdyld.dylib (655.1.1) <002418CC-AD11-3D10-865B-015591D24E6C> /usr/lib/system/libdyld.dylib
0x7fff69837000 -     0x7fff69837ffb  libkeymgr.dylib (30) <0D0F9CA2-8D5A-3273-8723-59987B5827F2> /usr/lib/system/libkeymgr.dylib
0x7fff69838000 -     0x7fff69844ff3  libkxld.dylib (4903.271.2) <FBF128C8-D3F0-36B6-983A-A63B8A3E0E52> /usr/lib/system/libkxld.dylib
0x7fff69845000 -     0x7fff69845ff7  liblaunch.dylib (1336.261.2) <2B07E27E-D404-3E98-9D28-BCA641E5C479> /usr/lib/system/liblaunch.dylib
0x7fff69846000 -     0x7fff6984bfff  libmacho.dylib (927.0.3) <A377D608-77AB-3F6E-90F0-B4F251A5C12F> /usr/lib/system/libmacho.dylib
0x7fff6984c000 -     0x7fff6984effb  libquarantine.dylib (86.220.1) <6D0BC770-7348-3608-9254-F7FFBD347634> /usr/lib/system/libquarantine.dylib
0x7fff6984f000 -     0x7fff69850ff7  libremovefile.dylib (45.200.2) <9FBEB2FF-EEBE-31BC-BCFC-C71F8D0E99B6> /usr/lib/system/libremovefile.dylib
0x7fff69851000 -     0x7fff69868ff3  libsystem_asl.dylib (356.200.4) <A62A7249-38B8-33FA-9875-F1852590796C> /usr/lib/system/libsystem_asl.dylib
0x7fff69869000 -     0x7fff69869ff7  libsystem_blocks.dylib (73) <A453E8EE-860D-3CED-B5DC-BE54E9DB4348> /usr/lib/system/libsystem_blocks.dylib
0x7fff6986a000 -     0x7fff698f1fff  libsystem_c.dylib (1272.250.1) <7EDACF78-2FA3-35B8-B051-D70475A35117> /usr/lib/system/libsystem_c.dylib
0x7fff698f2000 -     0x7fff698f5ffb  libsystem_configuration.dylib (963.270.3) <2B4A836D-68A4-33E6-8D48-CD4486B03387> /usr/lib/system/libsystem_configuration.dylib
0x7fff698f6000 -     0x7fff698f9ff7  libsystem_coreservices.dylib (66) <719F75A4-74C5-3BA6-A09E-0C5A3E5889D7> /usr/lib/system/libsystem_coreservices.dylib
0x7fff698fa000 -     0x7fff69900fff  libsystem_darwin.dylib (1272.250.1) <EC9B39A5-9592-3577-8997-7DC721D20D8C> /usr/lib/system/libsystem_darwin.dylib
0x7fff69901000 -     0x7fff69907ff7  libsystem_dnssd.dylib (878.270.2) <E9A5ACCF-E35F-3909-AF0A-2A37CD217276> /usr/lib/system/libsystem_dnssd.dylib
0x7fff69908000 -     0x7fff69953ffb  libsystem_info.dylib (517.200.9) <D09D5AE0-2FDC-3A6D-93EC-729F931B1457> /usr/lib/system/libsystem_info.dylib
0x7fff69954000 -     0x7fff6997cff7  libsystem_kernel.dylib (4903.271.2) <EA204E3C-870B-30DD-B4AF-D1BB66420D14> /usr/lib/system/libsystem_kernel.dylib
0x7fff6997d000 -     0x7fff699c8ff7  libsystem_m.dylib (3158.200.7) <F19B6DB7-014F-3820-831F-389CCDA06EF6> /usr/lib/system/libsystem_m.dylib
0x7fff699c9000 -     0x7fff699f3fff  libsystem_malloc.dylib (166.270.1) <011F3AD0-8E6A-3A89-AE64-6E5F6840F30A> /usr/lib/system/libsystem_malloc.dylib
0x7fff699f4000 -     0x7fff699feff7  libsystem_networkextension.dylib (767.250.2) <FF06F13A-AEFE-3A27-A073-910EF78AEA36> /usr/lib/system/libsystem_networkextension.dylib
0x7fff699ff000 -     0x7fff69a06fff  libsystem_notify.dylib (172.200.21) <145B5CFC-CF73-33CE-BD3D-E8DDE268FFDE> /usr/lib/system/libsystem_notify.dylib
0x7fff69a07000 -     0x7fff69a10fef  libsystem_platform.dylib (177.270.1) <9D1FE5E4-EB7D-3B3F-A8D1-A96D9CF1348C> /usr/lib/system/libsystem_platform.dylib
0x7fff69a11000 -     0x7fff69a1bff7  libsystem_pthread.dylib (330.250.2) <2D5C08FF-484F-3D59-9132-CE1DCB3F76D7> /usr/lib/system/libsystem_pthread.dylib
0x7fff69a1c000 -     0x7fff69a1fff7  libsystem_sandbox.dylib (851.270.1) <9494594B-5199-3186-82AB-5FF8BED6EE16> /usr/lib/system/libsystem_sandbox.dylib
0x7fff69a20000 -     0x7fff69a22ff3  libsystem_secinit.dylib (30.260.2) <EF1EA47B-7B22-35E8-BD9B-F7003DCB96AE> /usr/lib/system/libsystem_secinit.dylib
0x7fff69a23000 -     0x7fff69a2aff3  libsystem_symptoms.dylib (820.267.1) <03F1C2DD-0F5A-3D9D-88F6-B26C0F94EB52> /usr/lib/system/libsystem_symptoms.dylib
0x7fff69a2b000 -     0x7fff69a40fff  libsystem_trace.dylib (906.260.1) <FC761C3B-5434-3A52-912D-F1B15FAA8EB2> /usr/lib/system/libsystem_trace.dylib
0x7fff69a42000 -     0x7fff69a47ffb  libunwind.dylib (35.4) <24A97A67-F017-3CFC-B0D0-6BD0224B1336> /usr/lib/system/libunwind.dylib
0x7fff69a48000 -     0x7fff69a77fff  libxpc.dylib (1336.261.2) <7DEE2300-6D8E-3C00-9C63-E3E80D56B0C4> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 1
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 115656
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=862.0M resident=0K(0%) swapped_out_or_unallocated=862.0M(100%)
Writable regions: Total=1.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.7G(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 2200K 4
CG image 88K 8
CoreAnimation 72K 7
CoreGraphics 8K 1
CoreImage 32K 4
CoreUI image data 644K 4
CoreUI image file 320K 4
Foundation 4K 1
Kernel Alloc Once 8K 1
MALLOC 406.2M 218
MALLOC guard page 32K 8
MALLOC_LARGE (reserved) 128K 1 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
Memory Tag 249 408K 2
OpenGL GLSL 256K 3
STACK GUARD 88K 22
Stack 106.7M 27
VM_ALLOCATE 484.2M 164
VM_ALLOCATE (reserved) 384.0M 1 reserved VM address space (unallocated)
DATA 167.8M 357
FONT_DATA 4K 1
GLSLBUILTINS 5176K 1
LINKEDIT 307.4M 85
TEXT 554.7M 338
UNICODE 564K 1
mapped file 115.5M 20
shared memory 2992K 9
TOTAL 2.9G 1297
TOTAL, minus reserved VM space 2.1G 1297
Model: iMac19,1, BootROM 220.270.93.0.0, 6 processors, Intel Core i5, 3.1 GHz, 8 GB, SMC 2.46f12
Graphics: kHW_AMDRadeonPro575XItem, Radeon Pro 575X, spdisplays_pcie_device, 4 GB
Memory Module: BANK 0/ChannelA-DIMM0, 4 GB, DDR4, 2667 MHz, SK Hynix, HMA851S6CJR6N-VK
Memory Module: BANK 2/ChannelB-DIMM0, 4 GB, DDR4, 2667 MHz, SK Hynix, HMA851S6CJR6N-VK
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Mar 28 2019 19:17:52 version 9.137.9.0.32.6.34 FWID 01-36f56c94
Bluetooth: Version 6.0.14d3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
PCI Card: LaCie Storage Controller, RAID Controller, Thunderbolt@133,0,0
USB Device: USB 3.1 Bus
USB Device: USB3.1 Hub
USB Device: FA GoFlex Desk
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB2.1 Hub
USB Device: Apple Optical USB Mouse
USB Device: CP1500PFCLCD
USB Device: Scarlett 2i4 USB
USB Device: USB to ATA/ATAPI Bridge
USB Device: Algoltek USB-C Billboard
USB Device: Apple USB SuperDrive
Thunderbolt Bus: iMac, Apple Inc., 42.1
Thunderbolt Device: 5big Thunderbolt 2, LaCie, 3, 24.1
Hi, thanks for the report. I think you should report the bug here: https://www.graswald3d.com/support
G Scatter add-on is not developed by Blender developers so reporting an issue to the add-on developer will be useful :)
