node wranglwer CTRL+SHIFT+T
Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.14760 Core Profile Context 21.2.3 27.20.14535.3005
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: rB3e85bb34d0d7
Addon Information
Name: Node Wrangler (3, 37)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
node wranglwer CTRL+SHIFT+T isnt working
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.Oct 8 2021, 8:26 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Blender 2.90.1 is no longer officially supported. You should use the latest version of Blender, either 2.93.X or 3.0 alpha as these contain the latest bug fixes, potentially including a bug fix for this.
2.93.X: https://www.blender.org/download/
3.0 Alpha: https://builder.blender.org/download/daily/
You might also need to check your keymap to make sure this issue isn't caused by an incorrect keymap.
when i click control shift t it shows some error message and i have already enabled node wrangler
The error message is most likely that you have to click on the Principled Shader Node to select it in order to make ctrl shift T work.
