Error exporting as stl file
Operating system: macOS-11.6-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 48 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.6.20
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: rBb7205031cec4
Addon Information
Name: 3D-Print Toolbox ()
Author: Campbell Barton
Error exporting as stl file.
I have a 3d model, divided into parts for 3d printing and in edit mode, I select one of the parts to export it and the error that I attach appears. Thank you
object selection
change to edit mode
N (deploy 3D-Print Toolbox)
export option
STL format
to export
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 3 2021, 10:25 AM
Hi, thanks for the report. I am not able to reproduce this on 2.93.6 and master: cea7ee7582db4c4a300893cc80c52d3b270546f2
Does this happen on exporting specific object? Could you please add a simple .blend file where the issue occurs
