Cuda failing to respect texture coordinate for image vector in principle Hair BSDF
Operating system: Windows 10
Graphics card: GTX 1080
Broken: 3.0
master.79425ed32676-windows.amd64-release
Worked: 2.93.5
Cuda would map to the first point in a UV because when I use a mapping node and use location I can move it across to parts of my image to an individual pixel on that image.
OptiX and CPU/only works without issue.
https://i.imgur.com/Ea4DNep.png
https://i.imgur.com/NrG5gfU.png
https://i.imgur.com/68OHWHp.png
The issue still present in :
master.4b31a21bcd19-windows.amd64-release
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Oct 13 2021, 11:20 PM
Can confirm 3.0 not working, can't open this file with 2.93.4 - it says file format not supported. I am not aware of such break in compatibility though @Marcus Stange (Toys0125) is this something that happens on your end too?
@Richard Antalik (ISS) I would believe they added no compatibility patch temporally to prevent 3.0 blend files from breaking unexpectedly. They might add it back in a later patch. I also tested that you can still back port if needed with copy and pasting data blocks between blenders usually with a version number at a time. I did a 3.0->2.95->2.94->2.93->2.90 testing to see if it was bugged in any earlier versions.
Well I can open files saved with 3.0 in older versions, that's why I am wondering. In any case it's not relevant to this issue.
Does anyone know when this first occurred or has it always happened with CyclesX?
William Leeson (leesonw) triaged this task as High priority.Oct 14 2021, 9:30 PM
William Leeson (leesonw) lowered the priority of this task from High to Normal.
I came across this in the victor benchmark scene, I have a fix in the works.
Brecht Van Lommel (brecht) triaged this task as High priority.Oct 14 2021, 10:24 PM
So tried testing with the eariler verisons that in blender builds blender-3.0.0-alpha+cycles-x.b8238733598d-windows.amd64-release also have the issue where it says file not supported. Still can copy and paste into blender without issue. And it does render correctly in blender with cuda. But funny enough that EVEE did not work correctly. https://i.imgur.com/3dZd1lX.png
https://i.imgur.com/ONVvKQE.jpeg
Will test more later.
