Cycles shutting Blender 3.0 alpha down for no (good) reason.
Operating system: W10
Graphics card: Nvidia RTX3000
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Blender 3.0 Alpha
Everytime i try to render in cycles it shuts down inmediatly. No errors, nothing. Even when i try to render the default cube.
In blender 2.93.5 it works all fine, and even if i render in EEVEE in 3.0 alpha it works perfectly. Really can't find any solution why cycles shuts blender down within half a second without any warnings.
Any cycles render.
Thomas Dinges (dingto) changed the task status from Needs Triage to Needs Information from User.Oct 19 2021, 2:12 PM
What is your driver version? Do you have the latest GPU driver installed? And which exact version of Blender 3.0 do you run?
