VP9 source video results in borked render
Closed, DuplicatePublic
Operating system: Arch Linux
Graphics card: AMD Polaris 22 (DRM 3.42.0, 5.14.12-arch1-1, LLVM 12.0.1)
Broken: 2.93.5, commit date: 2021-10-05 12:04, hash: a791bdabd0b2
After importing VP9 video and trying to render I got blocky render.
  1. Loaded default environment and chose "Video Editing"
  2. Uploaded video file
  3. Made simple modifications (split, audio replacement) without touching video parameters
  4. Render video
Source video information (from ffmpeg -i):
Input #0, matroska,webm, from 'filename.mkv':
  Metadata:
    ENCODER         : Lavf58.76.100
  Duration: 00:03:20.11, start: 0.000000, bitrate: 348 kb/s
  Stream #0:0(eng): Video: vp9 (Profile 0), yuv420p(tv), 480x360, SAR 1:1 DAR 4:3, 24.87 fps, 24.87 tbr, 1k tbn, 1k tbc (default)
    Metadata:
      DURATION        : 00:03:20.000000000
  Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp (default)
    Metadata:
      HANDLER_NAME    : SoundHandler
      VENDOR_ID       : [0][0][0][0]
      DURATION        : 00:03:20.109000000
I do not use accelerated rendering.
I tried to change output parameters for video:
  • Raw PNG frames
  • MPEG-4 + H.264 Good
  • MPEG-4 + H.264 Loseless
  • MKV + H.264 Good
  • WebM + VP9 Good
Every time render gets borked. Preview shows original quality which isn't as bad as seen on screenshots.
When I converted source from MKV+VP9 to MPEG-4+H.264 blender finished render without artifacts.
To reproduce the problem, a video file with the same specifications seems to be needed.
I haven't found a file like that to test, so I'm tagging the VFX team, (in case they have a file like that and can take a look at the problem).
Evan Wilson (EAW) changed the task status from Needs Triage to Needs Information from User.Oct 25 2021, 3:51 AM
I was thinking that this was most likely a duplicate of T91405: VSE: Block artefacts in WEBM video on preview or export, but you are saying that the preview is ok? Can you upload a sample video?
I don't think it's quite possible (mostly from legal perspective I guess) but if it's fine I could send it via e-mail to someone.
@Maxim (gudvinr) can you send video to richardantalik@gmail.com? I would like to investigate it.
@Richard Antalik (ISS) sure, I sent you video at 2021-11-07. Didn't get a reply though so there's this comment.
Sorry I was away for a week, but I have pushed fix yesterday, so issue should be fixed.
