Linux Mint 20.2 Cinnamon - kernel 5.11.0-38
3400G
Broken:
From - cycles-x-blender-3.0.0-1dea1d93d39a-linux64.tar.xz
to - blender-3.0.0-alpha+master.8c21667f3ca7-linux.x86_64-release.tar.xz
Worked:
blender-2.93.5-linux-x64.tar.xz
For hair transmission, GlossInd is producing halos, and TransInd seems to be missing some light.
- open the 'Hair transmission - GlossInd, TransInd passes issue.blend' and press F12
- close the render window
- in the Compositing window compare the GlossInd and TransInd passes with Blender versions 2.9.3 and 3.0.0
GlossInd - 2.9.3
GlossInd - 3.0.0
TransInd - 2.9.3
TransInd - 3.0.0
Notes:
Only seems to affect hair transmission for those 2 passes, hair reflection works as expected.
While a hair shader is normally a mix of reflection and transmission, or Principled Hair, the above .blend file was specifically created to help highlight the issue found during normal compositing of several passes for a room-set file.
