Operating system: Windows 10
Graphics card: GeForce GTX 1080 (Nvidia driver 461.72)
Blender Version: 2.93.x
- Output log: ------------------------------------------------------------------
Warning! Using result of ChoosePixelFormat.
Win32 Error# (127): The specified procedure could not be found.
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF89D761F21
Module : VCRUNTIME140.dll
Thread : 00005680
Blender 2.93.5 (hash a791bdabd0b2 built 2021-10-06 06:44:49)
Read prefs: C:\Users\ralvarez\AppData\Roaming\Blender Foundation\Blender\2.93\config\userpref.blend
Read blend: E:\share\cloud\clients\SquidNet\sync\bmw/bmw27_gpu.blend
Writing: C:\Users\ralvarez\AppData\Local\Temp\bmw27_gpu.crash.txt
- Setup ------------------------------------------------------------------
Blender crash when submitting an EEVEE GPU render job using Blender latest (2.93.5) as a background task under a Windows 10 service.
The process that spawns the render job is a Windows 10 service. The same execution logic works for all other Blender jobs (CYCLES, CPU, GPU, etc...) but only fails when specifying EEVEE as the main renderer. If executed from a DOS terminal everything works as expected (ie; no crash) ( see render command command below)
Render command:
\\WDMYCLOUDEX4\Public\SquidNet\Applications\blender-2.93.5-windows-x64\blender.exe -b E:\share\cloud\clients\SquidNet\sync\bmw/bmw27_gpu.blend -x 1 -s 2 -e 2 -j 1 -F PNG -E BLENDER_EEVEE -P "C:\Program Files\SquidNetSoftware\SquidNet\plugins\/blender/squidnet_blender_gpu_render.py" -o E:\share\jobs/SquidNet/user1/BLENDER_GPU/slices/slice-2/bme-gpu- -a -y
In this example, Blender is installed on network share folder. The same issue occurs when blender is started from a local disk folder as well.
