Node Wrangler (3, 38) can't work
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.55
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash: rBa791bdabd0b2
Addon Information
Name: Node Wrangler (3, 38)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
Python: Traceback (most recent call last):
File "G:\2.93.5\2.93\scripts\addons\node_wrangler.py", line 3274, in execute
  import_path = bpy.path.relpath(self.directory)
File "G:\2.93.5\2.93\scripts\modules\bpy\path.py", line 114, in relpath
  return "//" + _os.path.relpath(path, start)
File "G:\2.93.5\2.93\python\lib\ntpath.py", line 703, in relpath
  raise ValueError("path is on mount %r, start on mount %r" % (
ValueError: path is on mount 'H:', start on mount 'G:'
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 1 2021, 10:45 AM
Hi, thanks for the report. Please provide steps for reproducing the issue.
(A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports)
thank you to reply my answer
For details, you can refer to the blender fileI uploaded.
There is a more detailed problem report.(in the blender document)
I added a notepad in it, you can take a look,
I also write some information in the node window
Simply put, when using ctrl shift T at what point is an error reported
IF i put the picture in the G: that the addons can work
The result I want has been placed in the blender file
Pretty sure this is fixed in the latest release by D12221
If you can't update, then you need to uncheck 'Relative Path' in the right side panel.
Files can't have relative paths across Windows drives.
Hi @隋玉峰 (youngart) , could you please try again with fresh builds?: https://builder.blender.org/download/daily/
