Texture Alpha Invert not working
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0 Beta, branch: master, commit date: 2021-11-05 22:17, hash: rB7a5b8cb20284
Texture Properties Alpha invert doesn't work
  1. Go to Texture Paint
  2. Go to brush settings menu, then create a new texture mask
  3. Go to Texture Properties tab, and load an alpha image "black and white to use as brush texture"
  4. go to alpha menu in texture properties tab and click invert, that doesn't affect the brush or the alpha texture loaded in
PS. check the whole Alpha menu " Calculate, invert..." it seems that nothing work, but most importantly the invert
it should invert the black and white values
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Nov 8 2021, 1:08 PM
As far as I can tell, alpha values of the texture (when being used as a Texture Mask) are not used, just the intensity (calculated by the luminance of rgb -- which is not directly altered by the alpha).
So while inverting the Alpha does make a difference when using an alpha texture for the Texture of a brush, it does not when using it as a Texture Mask (again, flipping alpha does not alter the values directly).
This sounds like intended behavior, to be 100% sure, I'd like a Sculpt, Paint & Texture dev to confirm though.
To invert the Texture Mask values, I would assume using Colors > Color Ramp and flipping the color stops is the way to go?
Calculate seems to work for me btw. in case it does not, please provide an example .blend file with that image packed.
The Alpha check box and calculate option seem to work fine, the calculate activates the color ramp where i can invert the black and white yup, thanks for pointing that out :), but till now i can't figure out how or when the invert work, are you saying the invert works by inverting the rgb channels luminance of an image. if used only with brush mask? and the rgb colors if used in brush texture? i've tried uploading a colored image to the brush texture but it affects the luminance only if that's the case then it works i guess
Try this file (it uses an alpha texture as Texture [not as Mask Texture], Invert seems to work fine (it does not touch the colors, but flips the areas that are painted).
It never inverts rgb, it inverts alpha.
When using an alpha texture as Texture the area were painting takes place is determined by its alpha
When using a Mask Texture the area were painting takes place is determined by the luminance of the Mask Texture rgb
Philipp Oeser (lichtwerk) closed this task as Archived.Nov 8 2021, 2:50 PM
Actually, after inspecting code a little, I do think this is all working as intended (like described above), so really dont think this is a bug, will close.
(but of course feel free to comment again if issues persist)
