seperation in the 3.1 alpha
Operating system: Windows 10 Pro
Graphics card: GTX 1660 super
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) 3.1 alpha
Worked: (newest version of Blender that worked as expected) Haven't tested I only used 3.1
Short description of error separation in edit mode crashes the app
add mesh ->cube ->select it -> tab ->scale on Y axis -> extrude upward faces -> merge edges by scaling on Y/X axis to 0 and enable auto merge vertices ->select the new faces -> separate -> crashed
Related Objects
Thanks for the report. I am not able to reproduce on master. Probably same as T92629: Crash on mesh separate
Could you please try again with fresh builds?: https://builder.blender.org/download/daily/
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 10 2021, 7:33 AM
