Archimesh addon shows no object in 2.93.5
Operating system: windows
Graphics card:
Broken: 2.93.5
I can enable the archimesh addon and find it in menu, but when I want to create an object, door or window for example, I see nothing. there is no object. I can change the size and models, but I seen nothing but the origin. Am I making a rookie mistake? :)
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 9:17 AM
Does this happen even from the default startup file? What do you mean by "size and models", the controller objects of archimesh? Can you screenshot the scene after you add one of those meshes?
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
