Error Profil Brush of Carver
Graphics card: AMD Radeon(TM) Vega 8 Graphics ATI Technologies Inc. 4.5.13587 Core Profile Context 19.40.42 26.20.14042.2
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: rBb7205031cec4
Addon Information
Name: Carver (1, 2, 0)
Author: Pixivore, Cedric LEPILLER, Ted Milker, Clarkx
when trying to use the profil brush option with the B key it does not open the options of profiles of brushes for carver
Karel Paulette Olabuenaga Garzon (Lera_karel) renamed this task from Brush of Carver to Error Profil Brush of Carver.Nov 14 2021, 11:36 PM
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 23 2022, 9:21 AM
Can you first make sure that in the add-on preferences the profile brush mode has the key B assigned to it?
Can you also try this again with factory settings and only this add-on enabled? File > Defaults > Load Factory Settings.
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
