This is a very minor issue, but navigating node editor with 3d mouse device is very janky and almost impossible. However it works perfectly fine in some other 2d editors like UV editor .
I'm not sure if this issue is the same for newer 3d connexion devices. I'm using an old hp 3dconnexion spacepilot.
- Open Shader editor or Geometry node editor.
- Use 3d mouse device to navigate.
- Without pulling it up or pushing it down, try panning the view with 3d mouse.
(moving the view in some directions will be impossible)
